Reproducing the OR-Fab Tire Carrier (anyone got a OR-Fab carrier?)
Oct 12, 2018
71
45
Sahuarita, AZ
Doesn't look like the instructions are available online that I can see (not even at the link provided to the product above).
It's been a couple years since I installed mine. If I remember correctly, you basically have to loosen the bolts on the hinge-side of the carrier, lift the arm up, tighten the bolts back down, and check the contact between the arm and the latch. Repeat until you get the arm and latch to meet while under whatever load you're planning to carry.
Adjusting the arm without the tire or jerry cans does you no good, because the arm will sag the second you put any kind of weight on it and immediately throw off your work.
I have a 33x12.50 Duratrac spare tire and two jerry cans on my carrier. I was able to adjust it so that the arm meets the latch pretty much spot-on.
I’ll try it in the morning. What sucks is the can carrier uses the old style cans with a lip on the bottom. All I can find are rusted ones or Chinese. I am considering welding a plate on the bottom so I can use the new NATO style cans..
Jerry Bransford
TJ Guru
8,821
9,776
Escondido California
Buy a Jerry can holder to place the plastic container in. The holder has a bottom lip that fits the OR-Fab holders. That's how mine held my 5 gallon plastic NATO water container.
Like this...
Well what a nightmare. In the first pic, you can see my tire carrier (TC) Is way off.
Thinking there was a way to adjust it at the hinges, and a big nope..
It has to be correctly installed from the start. So I remove the striker plate and what do I find?? Rookie installer crap. This is the very reason I bought a car lift and do all my own work..
Keep drilling rookie, you will find it...so I dropped the striker plate and it’s fine now. This is a beefy carrier. I think it’s painted too as it’s flaking off in a few spots. That makes for an easy re-spray. I can see why this carrier is popular.....
Jerry Bransford
TJ Guru
8,821
9,776
The way I made sure my OR-Fab gate swung right into the driver's side latch was to compensate for the tire's weight by angling the passenger-side mount a tad so the driver's side of the swing-out gate was positioned just above its latch. That way the weight of the tire brought it down so it was then level. Nearly ten years later it still swings directly into the center of the driver's side latch.
Jeffreybomb
2004 Wrangler TJ X
223
151
Chicago, IL, United States
Holy crap! That's ridiculous. That's impatience and laziness on the part of the PO. I'll be the first to admit that this install was one of the most difficult installs I've done by myself on my TJ, but cutting corners with this beast is not the way to go.
Were you able to cover up the unused holes with some sealant or something?
Likes: Chris
Oct 12, 2018
71
45
Sahuarita, AZ
Yes, I sealed the holes and the lowered striker plate covers all of the miss drilled holes. I’m pretty good at this stuff and this install would take me about 4 hours for a perfect install. Measure 20 times and drill once.......
Likes: Jeffreybomb
Jeffreybomb
2004 Wrangler TJ X
223
151
Well whaddya know! I finally found the installation instructions!
It sounds like you've already got a handle on your kit, but I hope the link and info are of use to you in case you decide to delve a little deeper.
Now that I'm seeing the much clearer, color instructions online, I do remember bringing my laptop out to the garage. They're a lot better than the crappy photocopied black-and-white instructions that were originally shipped with the kit.
The step to which I was referring in a previous post is under the section marked "finish the installation":
In the step below it may be necessary, depending on your wheel and tire combination, to slightly align the tire carrier so that it hits above the striker plate cup. This is to allow for tire weight and tire carrier flex.
Align the kit tire carrier with the striker plate. Check to see if kit tire carrier closes and alignment is correct. If the alignment is not correct, loosen and adjust the kit hinge plate. Once alignment is achieved tighten hinge bolts, tailgate bolts, and kit bracket bolts.
I also wanted to mention that I slightly modified the jerry can aspect of my carrier: I added a Quick Fist mounting kit, which helped to eliminate the need for the wing nut, clamp, and threaded rods. The Quick Fists are made of rubber; you won't have metal scraping against metal when you're bouncing around on the trails.
I used a couple more of the Quick Fists included in the kit for a spot to mount a shovel or other tool. However, I wouldn't recommend using them to mount something as heavy as a hi-lift jack.
Further, I bought the Rampage jerry can tool kit and Rampage trail can. They're both very useful for helping de-clutter the inside of my TJ. I don't really have a problem with the lip of the can holder, so I haven't modified or added to it, though I do like @Jerry Bransford's suggestion.
