I’ve had an exhaust leak for a bit now and finally got to locating the leak. Turns out it’s leaks and not leak.
The first is where I suspected, at the seal to the engine block. The second is from a weld at the connection to the catalytic converter. I don’t know how to weld and I’m wondering what y’all’s opinions are of the best way to address it.
Should I find a welder and have it patched then, of course, address the seal to the block or should I just look into having the entire exhaust system replaced?
Thanks in advance for the advice.
