Hey everyone. I am attempting my first ever jeep rebuild. I am diving right in ambitiously, having never wrenched on a jeep; and now, doing a frame up rebuild.
I would love any links, tips, tricks or hard learned lessons you had found either pre or post build.
I have read lots in this forum and the things I always find different are regarding people changing things on existing builds and using that as their metric for it's worthiness. An example is trying to figure out what cam I should go with. The threads I found spoke to it not being worth the change.. but my current block doesn't have a cam, so one is needed regardless. Therefore finding one with maybe a bit better power, even marginal, is worth it. I need a new manifold/header, but in reality it will be a full system. Threads here speak to ease or fitting into existing setup or problems with rigidity of header to pipe and 4L torque. I have not welded any of the exhaust hangers to frame yet so all is negotiable.
The dirty for reference:
98' sport. Plan to use for rock crawling, then give to daughter later in life once she gaines permission to terrorize other drivers. Want to add enough power to engine to compensate for added rotating weight and hanging weight. Attempt to keep geometry good, but also keep powertrain tucked up as high as possible to give ground clearance for mentioned boulders.
Frame: Being shortened from non rusted yj? Motor mounts custom built into frame. Beefed up all suspension and arm linkage areas. Welded in front and rear steel bumpers. Welded into frame nuts for full length 1/4" plate steel skid plate with obvious needed cutouts. I welcome other found convenient holes and cutouts.
Motor: 4.0L went to machine shop to be checked and freshened from the 100k original miles. Cyinders bored .030.
Block and head decked .010. New pistons, wrist pins fit to care for known issues. Rods trued and weighed to balance. MLS gasket to account for decking.
Crank conditioned and balanced. New bearings. New arp main bolts.
Head (0630) assembled and springs tested at 55lbs. Plan to at very least gasket match the ports. Optional- comp cams had an off road cam that requires different springs and seals to accommodate a .450 lift.
Front axle: ultimate dana 44 including e-locker, trussed, chrome moly axles, and I believe a 5.12 gear (can't remember if it is a 5.12 or 5.11)
Rear axle: dana 44 with matching gear ratio and disc brakes. Needs e-locker, trussing, and chrome moly axles.
Future plans (at least until forum guidance shows me better/proper) in order of planned completion. Please feel free to fill holes/gaps noticed, give any advice, tips, links, or even change order to ease my build!
Thanks for taking the time to read!
- Build motor (Waiting on cam research) upcoming week.
- Weld rest of frame pieces and rear axle trusses. Send frame and axle housing out for zinc infused epoxy coating.
- Rebuild 32RH, new torque converter. Find proper sye.
- Buy and install suspension package, wheels and tires.
- Assemble rolling chassis.
- Debating fuel cell or using on hand factory fuel tank.
- Radiator, oil cooler, trans cooler (not sure on ac system or not.
- Plum system. (Notice how generic)
- Cut out and replace rusted and unfixable body pieces.
- Install body to chassis linkages and electronics
- Buy flat fenders w/inner fenders to attach front clip.
- Bedline (lizard coating) underbody and interior floor.
- Mate body and chassis.
- Build custom roll cage and find acceptable rocker rock guards and install.
- Install interior pieces. Buy and install new front seats with 5 point harness.
- Pull out of driveway, hope for best.
