You need the brackets that bolt to the back of the sport bar )if you don’t already have them under the padding) to which you attach the knuckles on the ends of the soft top frame.
You need door surrounds.
Maybe Mucket Seals…. Rubber footing that goes between the door surround and the tub rail.
Last thing you need is buy some Duplicolor Vinyl and Fabric paint and spray the underside of the soft top. Looks a million times better. You’ll thank me later
There are a gojillion vids on the Tube on how to deploy and remove the soft top. It isn’t rocket surgery but some folks seem to get brain freeze when it comes to putting the top up and down.
