I am experiencing poor return to center on my '98 and I'd like some advice or thoughts on the issue. Here are the facts:
- Steering wheel only returns back to 11:00 and 1:00
- OEM Saginaw steering gear, 103,000 miles on the Jeep. It does have a small leak that isn't fixed with stop leak
- I've installed (earlier this year) H&R springs that netted 1.5" of lift (I don't have a comparison of before and after for steering, I put the lift on pretty much right after I bought it)
- 31x10.5 tires (running at 30 psi today, was a little lower than that before so I added some pressure to see if that did it, and there was no change)
- I removed the steering damper to see if that was the issue, no change
- I've replaced almost all of the front steering components, all the remaining ball joints are in good shape
- Toe-in is slightly less than 1/8” closer in front
- I measured the front pinion angle at 6* from 0 (as measured from the front inspection ports). Correct me if I'm wrong here, but based off the fact that the relationship between Pinion angle and Caster angle on a Dana 30 in a TJ is 12 degrees, that puts my Caster at 6* as well (I checked this as best I could with my angle finder and was also getting right at 6*).
