Revolution 5.13 gear set
All I see is the pinion spline count, not the axle shaft spline count.
It also appears that that is the thin ring gear for the Dana 44. If your current carrier is 3.73 or lower, you need a new carrier.
Thank you very much. I appears that is not the kit I am looking for. I do have 3.73's in the back. The front is 3.55's so it will definitely need a new carrier. I will search again.
Thanks!!
Thanks!!
Revolution, and other gear mfgs., do make a thick ring gear for the Dana 44 that will fit the 3.73 carrier. I believe It's the same as the one for the Rubicon D44s.
Yes RGA part number is the same but with TD added to the thick gears.
Be careful though ordering for the HP30. Last time I checked they don't make thick cut gears in reverse rotation. Get the correct carrier. In my case I had a brand new ARB that was for 3:54 and down. I had to buy a new case for it for the deeper gears.
And in your post, the 24 spline count was for the pinion, not axle shafts. Also, if your LJ is a Rubicon, buy accordingly.
So I received a response from Rigidaxle on a different listing that looks like it is what I need. Am I correct that the below listed parts will be correct for my HP Dana 30 and rear Dana 44. Just wanted to verify before I ordered the parts. Thanks!
New message from: rigidaxle (1,698
Package Includes:
(1) Revolution 5.13 Dana 30 Front Reverse Ring and Pinion Gear Set
(1) Revolution Front Master Bearing Install Kit
(1) Revolution 5.13 Dana 44 THICK Rear Ring and Pinion Gear Set
(1) Revolution Rear Master Bearing Install Kit
This kit should fit your application.​
Make sure to like us on Facebook and follow us on Instagram and Twitter.
- @rigidaxle
- www.RigidAxle.com
@hosejockey61
New message from: rigidaxle (1,698View attachment 243456)​
Package Includes:
- @rigidaxle
- www.RigidAxle.com
Package Includes:
- @rigidaxle
- www.RigidAxle.com
You will still need a new front carrier, but the rest is good.
