Rocker guard
Not available for purchase. They're custom hand drawn sliders.
I was not aware that Rubicon had stock sliders. Not many Rubicons around here. Actually not even one.
There's two different ones: the "enhanced" rocker which has a bar that sticks off and the rubicon one, which is diamond plate. Neither is super thick, however, so if you come down on them hard you'll find some bends in the tub, even more-so if you have the ones with the added lever.
Reactions: jjvw
If you want the same look as the Rubicon but you don't want the diamond plate tin foil they are made of that's exactly what UCF sells. Same deal except 3/16" steel. It uses the same mounting holes and is lower than most of the other options out there just like the factory guards.
<GASP> you posted something other than Savvy! :eek:
  • Face Palm
Reactions: rasband
