RockJock CurrectLync steering system worn out after only 1.5 years
Dang, sounds like we used to be neighbors. ✌️
I lived in San Diego County and Antelope Valley '78-2019, moved overseas in 2019, 2020 I bought a house in FL and moved to Jacksonville in 2021.
Lots of fond memories in CA, NV, AZ, an WA until their political insanity forced me to move.
Reactions: GregBelleville
Since you went there, what they are doing is the equivalent of getting on here and telling everyone your tires are under inflated because they are flat on the bottom. Of course, that is wrong because that isn't how it works and it is just as wrong as compressing the spring in a TRE and proclaiming it defective, or worn out. It has nothing at all to do with being a fucking fanboi or hater and everything to do with the proper way to test wear in a steering system regardless of manufacturer. The problem with the tolerence of fuckwittedness is if they applied the same test to their new different brand system, it will fail in the exact same manner.
You ok? You’re very emotional about this topic.
