There's not much to show as far as progress, since it's a lot of basic things like wiring. But so far both wiring harnesses are in all the way to the bell housing. The manual flywheel is in.
We patched a decent number of issues in both wiring harnesses and swapped over things like where I relocated the locker pumps.
There was a bit of burnt time working on various ways to get the crank bushing out of the former auto.
Blaine gave us a few heads up things that we navigated, such as swapping the ignition interlock. On the manual it's a switch you hit with your fingers, on the auto it's actuated by the shifter. The auto one, however, has a small piece that could be easy to lose.
Mine should go back together fairly quickly for the parts that need to. Crank bushing, Flex plate, transmission, transfer case, rear DS and gas tank. I'm going to buy another pigtail for my gas tank so I can disconnect it without dropping it - that's a dumb design. Any other things I have to put back in (skids, front DS, etc) I can do at home.
One extra thing I brought in anticipation of this work is p-clamps to rework my fuel lines to place them closer to how I've seen Blaine do on a few builds.
We've been fortunate in a few ways, such as having the in-cab wiring being common. Mine has things like the OD switch and shifter light already, and his has things like the clutch interlock. He wasn't super thrilled when we thought he'd have the fuse delete many of us already do baked in.
