NOTNSUV NOW I Know! Supporting Member Joined Sep 18, 2021 Messages 1,792 Location Spring Creek, NV May 22, 2022 #1 Do the rollbar pads above the door need to be removed for door surround install?
T TRE3TOP Guest May 22, 2022 #2 NOTNSUV said: Do the rollbar pads above the door need to be removed for door surround install? Click to expand... No
OP NOTNSUV NOW I Know! Supporting Member Joined Sep 18, 2021 Messages 1,792 Location Spring Creek, NV May 22, 2022 #3 RockHard roll cage. Are there vertical holes in the OEM cage to accept the Bestop threaded knobs?
P pagrey TJ Guru Supporting Member Joined Apr 10, 2018 Messages 7,725 Location Los Angeles, CA, USA May 22, 2022 #4 I don't know about Bestop but the factory door surrounds and knobs thread into the factory windshield support bars.
OP NOTNSUV NOW I Know! Supporting Member Joined Sep 18, 2021 Messages 1,792 Location Spring Creek, NV May 22, 2022 #5 pagrey said: I don't know about Bestop but the factory door surrounds and knobs thread into the factory windshield support bars. Click to expand... Not factory roll bar (windshield support bar). Pretty sure Bestop would use what you're talking about for factory but RH has no provision for that. The surround clips right on the roll cage but needs vertical holes for the threaded knobs. Guess it's time to drill my own. Reactions: pagrey
