Probably not ideal, but it came from Warn that way.That thimble is not really for a rope.
For $10, you can avoid problems on the trail.Probably not ideal, but it came from Warn that way.
It isn't. Warn isn't paying attention like they used to.Looks like it's doing the same thing as mine.
Although, the edges don't look as sharp.
Also, one of the reviews say it's not big enough for 3/8 rope.
Yep I would rather they go back to a soft eye than use the crap they are right now.It isn't. Warn isn't paying attention like they used to.
Not paying attention can get them in trouble.It isn't. Warn isn't paying attention like they used to.
Ok, google is your friend, find one that has reviews you are good with. I was just showing what the difference is. The one you have is NOT for synthetic rope. Be careful.Looks like it's doing the same thing as mine.
Threading the thimble is sooooo easy once you know how. I think the tool is called a fid. A gutted sharpie is what it looks like.It looking like crap is one thing, working like crap is another. Are breaks near the thimble common with this style? Either way learning how to make the loop is worthwhile regardless of the thimble. If it breaks on the trail you don't need a thimble at all in my opinion. You'll get a few pulls on plain rope and you can research other options when you get home.
Know the fid, used a 3/4 for this kinetic.Threading the thimble is sooooo easy once you know how. I think the tool is called a fid. A gutted sharpie is what it looks like.
That is some huge rope!
Same size TRE sells. It's been a challenge to get that knot down but a good learning experience. I bought some ATV synthetic winch line and have been tying knots in that for my kayak. Someday I'll make the switch on my Jeep.That is some huge rope!
I had occasion to splice on 2 thimbles recently. One was on some of the early line they included, one was a recent purchase. If you have handled line you can pretty much tell where it was made. The early almost certainly has to be Samson, has the same soft hand, fibers are easily snagged with the fid, doesn't open up very far when you shove the fid through. If you aren't using a pusher, it is very hard to milk the outer braid over the fid and down onto the tail. It is also very slippery which makes it harder.Yep I would rather they go back to a soft eye than use the crap they are right now.
Sooo, what do you do with those 15’ drops?I had occasion to splice on 2 thimbles recently. One was on some of the early line they included, one was a recent purchase. If you have handled line you can pretty much tell where it was made. The early almost certainly has to be Samson, has the same soft hand, fibers are easily snagged with the fid, doesn't open up very far when you shove the fid through. If you aren't using a pusher, it is very hard to milk the outer braid over the fid and down onto the tail. It is also very slippery which makes it harder.
Contrary to the latest stuff which is either coming out of China or they copied it exactly. Stiffer, heavier hand, opens up easier, very easy to splice, fid goes right through.
Someone really needs to sit down and have a chat with their technical department. You can NOT spec out a line length that used to work, increase the actual line diameter and shove that in this ginormous "heat" guard without adding bulk. It is ridiculous that they miss the basics now. Owner get a bit grumpy when they see me hack off 15' of their expensive line just to almost not overfill the drum.
Warns history with synthetic line I would call at best comical. They started with flat out saying it should not be used on their winches when it first became popular because the brake could melt the rope. So to solve the heat problem they offered the most complicated and expensive line when they spliced a "crystal polymer" line to Amsteel. I can remember the ridicule on pirate they got over that. The funny thing is the answer to the heat problem was to not winch out under load for extended periods of time.I had occasion to splice on 2 thimbles recently. One was on some of the early line they included, one was a recent purchase. If you have handled line you can pretty much tell where it was made. The early almost certainly has to be Samson, has the same soft hand, fibers are easily snagged with the fid, doesn't open up very far when you shove the fid through. If you aren't using a pusher, it is very hard to milk the outer braid over the fid and down onto the tail. It is also very slippery which makes it harder.
