I've been dealing with a reoccurring issue where on start up my RPMs are erratic. It started where it would idle fine, and stumble under accelertion until the engine warmed up. It was worse the colder the outside temperature was.
It progressed to where it would idle erratically until it warmed up. It also threw a p0121. I unplugged the TPS and it idled fine, so I replaced the TPS (with a Mopar one). It solved it for a while, but now the problem is back.
Is there a possible concurrent problem? I'm out of town for work, but want to get ideas to check before I get back. I'll definitely check the new TPS.
Could a vacuum leak or bad ground be the culprit? It was warmer outside when I put the new sensor in, so it could have been fine when I was replacing the sensor.
