RPMs jump when shifting clutch
Phillip04
Fall Branch Tennessee
Hey guys I have a 2004 wrangler x with the 4.0 motor. Here lately when I press in the clutch when shifting up only the rpm’s will jump a couple hundred. It doesn’t do it all the time just every once in a while. Any ideas what it could be?
Reactions: Shatto
I would start by cleaning your Idle Air Controller (IAC):
https://wranglertjforum.com/threads/how-to-clean-your-iac-idle-air-controller-valve.662/
If that doesn't fix the problem, consider replacing your Throttle Position Sensor (TPS). Sensors in our TJs should always be replaced with the Mopar version, as aftermarket brands are typically junk. I had a similar issue where the RPMs would jump to about 2,000 when I would push in the clutch. A new Mopar TPS fixed my issue.
Reactions: Shatto and Chris
X2, this is where I would start.
Reactions: Shatto
Thanks
Thanks! I’ll have to try that because that’s about where mine will jump up to and if I’m already at 2,000 RPMs it won’t do it.
Reactions: Shatto
You already have the answer I would have given; but my story may help with diagnosing this and other problems.
I had a .... I'm lazy; it's between the picture of the valves and the rocker arms.
https://www.allpar.com/cars/stories/shatto.php
