Ok so I had the transmission replace about 8 months ago as well as sending my computer off to F1.
In May I went to a jeep event down here (FL) and decided to drive thru one of the mud holes, well lets just say I had about 10 inches of water inside the cab, with 37s, 4.5 lift and 1 inch body (4.88gears). But the time I got pulled out my and drove around my jeep started to overheat. So I shut it off. Found out that it was my fan clutch went bad, im guessing due to the water hitting it and it being old. (I changed all diff fluids, checked tranny and oil fluid all good as well as a new fan clutch).
Well after a week or 2 of driving around my jeep started squealing at higher RPMs and then it wouldnt shift with out letting off the gas, as well as worse mpg 14 to 11. So I ran it by the transmission shop and they said it was either fuel related or a clogged cat. Well the cat I could understand since its stock exhaust with 180k. Good time to upgrade the exhaust. Replace everything from headers back (I removed the 3rd cat since no sensor). Still have the problem. Next I dropped it off at the jeep dealership because I knew the service manager. They tested all fuel pressure and flow (good), replaced distributor, we repaced the old fan clutch and upgraded to electric, checked compression all around 158, checked spark plugs (they look good). Then they returned it to me. When I drove it no more fan clutch locking up and squealing, awesome. But when I gave it gas it still couldnt get out of its own way. And transimission wouldnt shift at high RPMs.
Sooo I brought it back the the transmission guy to check it out again. He hooked the computer up to the jeep while driving it. Still no codes, no check engine light (never had a light on during this whole time). but you could feel that it couldnt get out of its own way. We couldnt even get it up to 65 mph. He really thought it was fuel related. Saying that its dumping to much fuel and could be a o2 sensor. Well I just replaced all o2 senors (NGK) today, the old ones we cover black. But everything Still running the same after changing them all.
So whats next MAP senor?
