That looks like a jeep that tumbled down Blackbear pass on YouTube.
No, that Jeep you mentioned looked like it went through a car compactor...
Removing the antiswaybars on a leaf spring vehicle is fine, not so much on a coil spring suspension like the TJ has. Coil springs are unstable in any direction, leaf springs are stable in all directions except up/down.
You're not picking up any USABLE additional rear flex by keeping the rear antiswaybar. Only newbies believe they're getting more flex without their TJ's antiswaybars.
John Currie won the overall US National ARCA rock crawling championship running his Antirock version of the antiswaybars on the front and rear. If removing the antiswaybars actually helped people doing competitive rock crawling like John Currie did they wouldn't run them. However, they do. And most serious rock crawlers running TJs run f/r antiswaybars, I do on my TJ.
I was at the final ARCA championship event held in Johnson Valley and took these photos of John Currie's Fireant TJ. Look carefully, you'll see its front and rear Antirock antiswaybars. Most serious rock crawlers run f/r antiswaybars on their TJ. I run the factory antiswaybar in the rear and Currie's Antirock antiswaybar in the front of my TJ.
Kinda-sorta but the coil springs are unstable in all directions where leaf springs are not. That's why leaf spring suspensions can get away without antiswaybars and (usually) track bars without problem.Leafs and coils are doing the same thing. The only difference is that leafs locate the axle.
A coil spring can be moved/move in any direction. There's not a single direction a coil spring is stable in. I thought that would be pretty apparent to anyone who has seen a coil spring up close. Leaf springs don't readily move sideways, just up and down.Define or explain further on "unstable in all directions" please. I do not understand that comment.
We'll have to agree to disagree.Coil springs are not unstable in the way you are describing. And especially not in the case in a TJ where they are restrained top and bottom. I thought that was apparent to anyone who has seen a TJ up close![]()
