Rust Buster upper rear coil buckets
Dirt_Reynolds
West Virginia
I bought these second hand so I have no way of knowing the right from the left side. Should the arrow point to the inside or outside of the frame ?
FireJeep
Virginia
Since no one else has answered you I will give my best guess, the arrow is to the inside since there is a cross member there and the lack of bracketry would allow for the clearance needed. Also, the long bracket makes for solid welding on the outside of the frame rail..... just my 2 cents.......
someguysjeep
simple guy
Lifetime Supporting Member
ohio
i don't really recall but think the rear springs are favored inward. shouldn't be hard to tell look down the rail is more spring inside the frame rail or outside.
is your jeep lifted? are you also relocating them to the top of the arch at this time?
