I would neither take one for free nor install a free one. I've made a point of asking every owner of one that is under the hood of any rig I've worked on how many times they have replaced the relay board in the box. The answer is never zero. I started doing that after a few friends complained about having to replace the underhood part. Not for me.
But, there is no comparison if you look at the relay and fuse box I have laying on the scale. That is the equivalent to the relay box sPod has you mount under the hood. Equivalent part.
Being acutely aware of the need to access the shift tower shift handle shoulder bolts from both sides, we do a removeable close out panel. Also, the shift boot is an odd duck in that it needs to have the long axis about 45 degrees to the shifter path. If you put it longways like logic dictates, the accordions bind up since the shifters are one behind the other. The metal ring is also the wrong size to work well. We made a new one and then a copy of it so it is easy to bolt it down without the screws wadding up the rubber.Back to the Atlas installation. I decided to fit up the shifter linkage assembly for the main case. First, I noticed that just from sitting in the box in my shop for about six months waiting to be installed, the threaded rods for the shift linkage were rusting pretty badly. They appear to be uncoated, in-the-white, steel, so I ordered up some 316 stainless threaded rods. Here's a picture of a rusted carbon steel rod and a 316 rod to replace it:
Next, I followed AA's instructions for assembling and fitting the shifters. To get it right was a very tedious process that took several hours. After getting them set up, I discovered more tub interference. The top of the tower that holds the levers hits the tub, and the front lever itself hits the tub:
I gained about an eighth-of-an-inch by sanding the top of the tower and putting a radius on the shoulder screw's head:
However, it wasn't enough. I could hear the tower hitting the tub while shifting, and upon removal, I found this witness mark on the freshly-painted screw head:
I'll have to bump out the tub in the areas marked up in the third photo up, but I'll do that when I have a plan to fix the kink in the floor. Stay tuned for that.
Oh, yeah - I forgot to add this comment to the post above. Another reason to dislike the Rubicon Express Long-arm Kit that was on this LJ when I bought it is that there are some large-diameter holes drilled into the frame right where I wanted to add more nutserts for the skid. I guess I'll have to weld in some circular patches before installing the nutserts:
I've spent an inordinate amount of time trying to work out a great way to use vertical tubes that are threaded for the skid bolts. All it takes is one loose bolt and a drop onto a rock to make that a miserable idea. And, it is only slightly less miserable that how offended I'd be using 5" long flat head through bolts. That said, I'm not convinced nutserts are that great other than we are very familiar with them.Or...don't bother with nutserts and weld tubing through the frame and bolt your skid through the tubing...I think @toximus did that when he replaced his frame rails.
That's really cool, I like your combination of new and old CAD. I'm trying to learn how to 3d model soon so I can 3d print some interior parts.
Well, I did it part time, for work, for about 15 years (using the original parametric modelling software - ProEngineer), and then I switched careers and became an engineering manager and didn't touch it for over 15 years before doing it again for this build, but this time using Fusion. Fusion is pretty easy to use, but having some design experience is very helpful. Learning it can be like a roller coaster - extremely satisfying one minute, extremely frustrating the next!
As the Nike pukes say, "Just do it."
I've spent the last three days working on a single part - the transmission mounting bracket. I have the transmission held up by a screw jack at the correct height, and I have a piece of the 1"x3" rectangular tubing that will be used for the cross member clamped to the bottom of the frame. Since the blank from @mrblaine has a 1" drop, the top of the 1"x3" tubing is exactly where it should be once installed, and the bottom of it represents the top of the skid, which is convenient for mocking up.
One of the biggest issues is that there is very little extra vertical space above and below the Atlas case because I want to use the factory rubber mount for the transmission so that I don't have to worry about vibration as much. I have less than 1/4" of room to play with, so I did a lot of real-CAD and old-school-CAD work, and dozens of trips from the computer/printer in the house and the LJ in shop (it's a 400' round trip each time!) Basically, I'd draw up the cross-section of the main plate for the mount, print it out on cardstock, cut it out with a scissors, and then test fit it, like this:
I just looked at my Fusion model, and I saved it 26 times. However, I didn't save it every time I made changes, so I'd guess I could have made close to 50 changes to it to get the fit just right! Here's some of the cardstock spent on this task:
And this is what I ended up designing (note - only one side plate is shown, but it will have one on each side):
As long as I didn't screw something up (), this should be a pretty simple weld-up and installation once SendCutSend gets it to me. Tomorrow, I'll either start on the cross-member or the skid mounting (probably the skid-mounting).
I am never posting any of my armatureish fab projects again…
That’s another nice piece of work, Scott.
One more thing - it's currently only nice on screen and on paper. Plenty of time to "louse it up," as my old man use to say.That’s another nice piece of work, Scott.
Jeff, thank you for the kind words, but I've seen your build thread - you're no amateur.
We both know the investment in time (not to mention money) it takes to do good work, don't we?
