As I suspected, this new job really put the binders on my build progress. I can really only work on the weekends now, but I had another homestead project to finish this weekend. Our aquifer in this area is drying up, and we have no public water supply available within about 10 miles of the homeplace. For the last five years, I've been preparing for the inevitable day when there's no more water by building an industrial-level rainwater collection and treatment system (35,000 gallons of tank capacity). It's a costly solution, both in time and in money. The gutter guy finally found the time to come put the gutters on all the buildings, so I had to seal all the gaps to keep insects out of the system (when we go three months without rain, the insects find every single water source around). That took all day.
Back to the build. Yesterday, I made and painted this bracket:
"What's it for?" you ask. It's for a microswitch on the planetary shift lever. After curing the paint in an oven overnight, I assembled it today:
My LJ came as a Rubicon, but I will be pretty much replacing all the Rubicon components. However, I wanted to keep the dash lights functional and the "start in gear" functionality when in low gear. The OEM switch on the NVG241OR transfer case tells the PCM when the transfer case is in 4WD and 4WD Low. Advance Adapters makes an electronic interface module to replace the Rubicon's transfer case position switch. It uses two ball switches - on the front and rear shift rods - to indicate 4WD and Low. However, the planetary box on the 4 speed has no such switch accommodation. I want the PCM to know I'm in Low when the planetary shifter is in the low position. To do that, I'll wire the microswitch in parallel with the ball switch for low gear on the rear shift rod. It's an SPDT, but I'm using only one throw (the blue and black wires.)
And that's all the progress for this week. Darn job.
Stay tuned!
Stay tuned!
