Savvy coil spring question
Karl
Vancouver Canada
So I’m looking to get some new springs. After everything I read I am drinking the koolaid and looking at savvy. I have a couple questions though.
I see rear springs that are 4.5 but the fronts are only 4. Are there some 4.5 fronts to match that I’m missing?
I also read on a thread that the old model numbers were 5 inches? And they recently changed the model number? I could give Currie a call but it’s the weekend.
Please enlighten me!
First, you must unlock Lemarchand's Box. Then everything will be clear. :unsure:
p.s. Or you can order the CURRIE 4" front and rear springs.
https://savvyoffroad.com/product-category/jeep-wrangler-1997-2006/suspension/springs-suspension/
The old springs never changed. Their free length is 22.6”. They used to advertise as 4”, but now 5” because some complained they gave more than 4”. Nothing has changed with the spring. The amount of lift you get is what you get based on the weight of your rig. The spring rate is comparatively low to accommodate a longer travel shock in the 11” range without unseating at full droop.
The new spring has a free length of 21.6” and the same spring rate, so it will give 1” less lift.
For all the details see
https://wranglertjforum.com/threads/tj-shock-spring-specification-resource-thread.47846/
Reactions: RINC and Irun
Check that those are for the tj. Currie does have a 1/2” taller spring for the LJ.
Technically true for the rear springs. But the reality is that the two options are there only to accommodate different weights.
