so I made a exciting purchase, a set of savvy double adj. rear uppers
I want to know if I have to do anything to them before I install them?
Pull the joint ends off, liberally coat the threads with anti-seize, re-install the joint ends, set to the recommended rough length, then install them.so I made a exciting purchase, a set of savvy double adj. rear uppers
Do they come with stickers?so I made a exciting purchase, a set of savvy double adj. rear uppers
Here are 7 pages you can read through.So do I need to grease them before I install them?
if so, how? and with what grease?
thanks, but im trying to find out if I grease them BEFORE I install them?Here are 7 pages you can read through.
https://wranglertjforum.com/threads/johnny-joint-maintenance.54875/
Most likely, yes. You should at least pull them apart and check if they need grease. The go-to grease is redline CV-2. That work great for all the guys out west. If you're in mud, it doesn't work that long. I'm experimenting with some energy suspension stuff.thanks, but im trying to find out if I grease them BEFORE I install them?
Agreed. I def did not take mine apart before install. Once “real” winter roles around, I’ll probably re-antisiezeI get they need grease as a preventative maintenance item but I would think Currie would pack them from the factory. Am I wrong?
Thanks, that's the advice I was looking forI put on an entire set of Savvy D.A. control arms a couple few months ago…
I put a more even coat of antiseize on all the J.J. threads. They probably had enough already…
All my J.J. looked like the were reasonably lubed upon arrival, so I didn’t bother adding additional. The grease was smeared/squished out around the perimeter of each pretty evenly so I felt ok about them…
Set my lowers to stock length and installed…
Set my pinion angle with one upper arm and then installed the other upper arm…
With you only doing the rear uppers right now it won’t take you long at all. Just make sure the threads have an even coating of antisieze on them. Make sure there is grease squeezing out around the J.J. Then get it done…
I’ve got 20 JJs on my rig (well 2 about to go on), after the first set (16 in the CAs) started creaking within about 8-9mo of install I opened up all the rest I put on and was surprised with how little grease was packed in there (basically just a little on the ball).I get they need grease as a preventative maintenance item but I would think Currie would pack them from the factory. Am I wrong?
That's the advice that tells you to do the least amount of work...Do some searching and you'll find that lately, there have been some instances of joints not being shipped with enough grease.Thanks, that's the advice I was looking for
my plan is to call savvy and ask themThat's the advice that tells you to do the least amount of work...Do some searching and you'll find that lately, there have been some instances of joints not being shipped with enough grease.
If it were me...I'd check them. You'll need to learn to disassemble them at some point, anyway. For two control arms I wouldn't bother with the tools (that cost as much as a set of CA's) so a couple long bolts and some sockets should do the trick. The one area not to cheap out is the snap ring pliers...
Savvy doesn't make the joints. RockJock does (well, Currie Enterprises). Savvy buys a RH and LH threaded JJ body and some Aluminum. They thread the aluminum, screw the JJ's in and Sell em.my plan is to call savvy and ask them
The least amount of work would be to receive the control arms, not inspect them and immediately install them…That's the advice that tells you to do the least amount of work...
You do you. I've had mine apart enough to know that grease on the outside doesn't mean grease on the inside.The least amount of work would be to receive the control arms, not inspect them and immediately install them…
There are four main things a person can do upon receiving their control arms:
1) Inspect them.
2) Add additional antiseize.
3) Add additional J.J. grease.
4) Install them.
If there is an adequate amount of grease squeezing out around the bushings, like there was on mine, there is absolutely zero reason to open them up. Which is why I told him to check before installing. Mine are absolutely squeak/noise free…
