I have read
@mrblaine comments on it on previous posts, so not worried about getting it in, just wasn’t sure if the bolts should be in there or not, they are all good I’ve got a message to Savvy, or I’ll get them myself.
Only thing that I didn’t see in his comments was the edge distance. Curious if there’s an edge distance you look to have?
Compilation of comments I have so the install I don’t think will be an issue:
Edge distance done first and then the front supports are done. More importantly you need the front working with the exhaust and that should give you enough or way more than enough edge distance at the skid. The front supports don't set where the skid goes, edge distance, side to side at the trans pan and clearance around the exhaust at the front do.
We don't grind. Yes, there is some slight interference on some of them, not all. When there is, we just snug the upper bolt down and push the lower end over until a hole lines up which tweaks the tab on the upper mount slightly. Not a big deal and we don't have to do it on all of them. Stupid Jeeps are not consistent so there is no way to always wind up with the same installation results.
We also always run the flange that points forward to the inboard side. That way they match which makes my OCD happy and gives us the most clearance for the upper on a mid arm install.
Bottom of both frame side motor mount brackets have two holes that match the holes in the brackets. They are offset and not straight across from each other so one bracket mounts one way and the other side is reversed so that both roughly line up with the front of the skid.
