Hi All,
Currently undergoing an axle swap and need to know where to mount the three link brackets on the front axle for the Savvy mid arm. Are there any measurements to go off of? Should the top link be centered on the axle vertically and some specific distance to the driver side of the axle center point? How far up does it go? IIRC the LCA brackets are just kept at the stock TJ locations - Would there be any detriment to moving them upward to keep the brackets out of the rocks? Would I need to compensate this change by raising the upper link too, for maintaining link separation, or is there more to it than that? Should I just not change anything? I'm guessing uptravel would become an issue if the uppers were moved up further, and would be a bigger deal than scratching my LCA brackets. Same questions for the rear, I'll be tackling that next.
Any help greatly appreciated! Apologies if this has been covered before, I couldn't find anything.
