The real question I have, is do they require a BL? That will tell some.Show us these ballistic brackets
Not even close to being like Savvy
Well then I guess that I won't be winning KOH or becoming Ride of the Month then . How dare I think that I can build my own system and not just buy the best one out there!!!
No offense, I’m all for creativity but why reinvent the wheel especially one that is proven?Well then I guess that I won't be winning KOH or becoming Ride of the Month then . How dare I think that I can build my own system and not just buy the best one out there!!!
Don't let them get to you. Haters gonna hate. The project you are about to undertake is pretty massive. My advice is take your time, tac things in place and cycle everything, problems will present themselves, and there WILL be problems. Fix accordingly. tac in place again and cycle again. repeat. Do not get in a hurry. Mostly have fun with it, and keep the mindset that its okay to cut the whole thing off and start again. If you wanted easy just buy the savvy kit and be done with it. remember a few posts back before I sent this tread on the suspension frequency tangent? Roll steer? that's why those brackets are not ideal. There will be lots of compromises because they were not made for a TJ. Your 4 link calculator will likely have Roll Steer figured in. Do you know what rear steer is? If not, no big deal, something else to research. You're probably better off making your own brackets. When you are all done, you will have something special. It's not going to be as good as the Savvy mid-arm, but it will be something you can be proud of. If you are good with this reality, then full speed ahead.Well then I guess that I won't be winning KOH or becoming Ride of the Month then . How dare I think that I can build my own system and not just buy the best one out there!!!
And there you go with your questions again. Yes, I know the difference.
And there you go with your questions again. . . .
Let us not forget what Socratic questioning got Socrates.
Looking forward to seeing what you build.
Nice to see that there are folks on here that are reasonable and not running around trying to prove that they are the smartest with every post. I really don't care what he says. I have been building shit-boxes since before he knew which way was up. I am 100% aware that I'm not a race truck fabricator but I have built and driven well over 20 trucks to and on the Rubicon, Fordyce, Moonrocks, JV and a few other spots between here and there. None have won any competitions but every one has been fun. This one will probably hop a little on climbs and maybe it will be a little unstable on side-hills but that's what wheeling is. I've laid trucks on their side and rolled them over and then cut the roof off and driven home wearing ski goggles. I'm a little older now and a little wiser but I'm still down for a good time.
That being said, this place is clearly not for me. Blaine is the man and Jerry has a picture of himself hi-centered. Have fun with your discussions, guys. I'm out. I've got work to do.
I, for one, will be sorry if @Rock Toy goes. He asked some good questions and I learned something about spring frequency in the short time he has been a member.
Wouldn’t survive on pirate Sad to see you go man @Rock ToySometimes, forums or the internet is t for everyone. I’ve seen people come and go over the years and sometimes you bounce until you find “home”. I took a 10 year break from forums and any form of social media, it did me good.
I too learned some good thing here and had nothing to provide to this discussion.
Best of luck @Rock Toy, you sound like an interesting guy who has done some things.
When you get done, provide a build updateNice to see that there are folks on here that are reasonable and not running around trying to prove that they are the smartest with every post. I really don't care what he says. I have been building shit-boxes since before he knew which way was up. I am 100% aware that I'm not a race truck fabricator but I have built and driven well over 20 trucks to and on the Rubicon, Fordyce, Moonrocks, JV and a few other spots between here and there. None have won any competitions but every one has been fun. This one will probably hop a little on climbs and maybe it will be a little unstable on side-hills but that's what wheeling is. I've laid trucks on their side and rolled them over and then cut the roof off and driven home wearing ski goggles. I'm a little older now and a little wiser but I'm still down for a good time.
No, you are correct... Well, I don't know about the passenger car vs the F1 bit.From what I've read and understood on this topic, suspension frequency is how fast the suspension travels up and then back down to the same point when you drive over a bump. If our Jeeps did not have shocks, the springs would continue to bounce up and down at this rate for quite some time.
The suspension frequency for each corner is your standard classic spring equation, f = 1/2pi *sqrt(k/M), where k is the spring rate and M is the total sprung mass in that corner, which is calculated as half the axle weight minus some calculated amount for unsprung mass (wheels, tires, suspension components ...). I would assume you want this number to be even left to right and front to back unless you have a special case vehicle.
To give perspective, passenger cars today have that number less than or around 1Hz. High speed race cars (think F1) that generate a lot of downforce will be around 5Hz. That's a five fold difference.
It is not clear to me how perceivable the difference in front vs rear susp frequencies in an hypothetical Jeep with different springs (and same shocks) will be. But, us humans are surprisingly sensitive to some things and I would not be surprised if you can feel (but not clearly explain) a difference like that. It might come out as just an uneven feeling ride. The springs we choose will very much have an impact. Shocks complicate things quite a bit on top. I think Currie knows about this much more than we do.
@Mike_H may know more than I do. Did I say anything incorrect here, Mike?
