Went out to empty the ashtray and this happened...
[/QUOTE
That ashtray is massive
Hmmm, I think my Jeep has figured out how to order it's own parts from Amazon.
Clean the throttle body.Thanks, now that I can drive it some, I discovered that it is idling high, around 1200-1500 most of the time. I looked over the vacuum lines that I could see and didn't see any issues.
Been there, done that. IAC too. New injectors, plugs, coil rail and PCM.Clean the throttle body.
Is the cable letting the throttle return all the way?Been there, done that. IAC too. New injectors, plugs, coil rail and PCM.
Post a video of how it sounds when you install your magnaflow.. I’d like to hear itIt’s going back together pretty well. The rest of the Magnaflow showed up today so tomorrow will be exhaust day.
Sure will. It's all installed. Will get something tomorrow.Post a video of how it sounds when you install your magnaflow.. I’d like to hear it
