Good excuse to put an AX-15 in there...might as well make a bad situation turn into an excuse for an upgrade!
I agree if I had actually been driving the TJ I would have felt and heard this failure happening and perhaps had time to stop prior the the catastrophic detonation. Unfortunately being in the tow vehicle i felt and heard nothing.I believe the two are unrelated. The front CV joint could have just as easily seized while you were driving it and had the same result, and was not related to the transmission being in neutral - though you'd have had warning and probably stopped if you'd been in the drivers seat because I think that joint usually starts making noise before it fails.
The mistake, if you're inclined to think of it as such, was not leaving the auto trans in N. That is most most likely completely unrelated to this scenario. I wouldn't even really think of this as a mistake. It was just time, based on age and/or miles/kms, for the centering ball in the front driveshaft to seize up. Failure in this manner is usually, but not always, preceded by a squeaking or chirping noise (referred to as the angry sparrows) from the front driveshaft. As you mentioned, they may not have been audible while towing the TJ. Had you heard them, the thing to do would have been to remove the front driveshaft to (a) confirm that the noise was in fact from the driveshaft, and (b) buy yourself some time by eliminating the potential failure point while considering repair/replacement options.Thanks for the many replies and sympathetic words. Yes I was flat towing with alkl wheels on the ground.
I accept that I have made a mistake in having the auto trans in N but am curious why it blew apart this time and not the first time I tried.
I have not yet contacted my Insurance company. Has anybody been able to make an insurance claim for this type of damage
Here are a few pic taken as soon as I discovered the issue. I will post more later today why I have the bottom plate removed
Here are some more pics. I wont be able to access the hoist for another four hours to get better pics Looks like the Auto Trans is damaged. See image 3772
All uJoints and Double Cardan are all intact and appear undamaged.View attachment 286479View attachment 286480View attachment 286481View attachment 286482
Thanks You are correct. Its only the Tranfer case. I guess I'm in panic mode at the moment.I'm still not seeing where you're seeing damage to the transmission. I added a red line to your photo - the trans is to the left of this line. The transfer case is to the right. What you're looking at in the opening is the range fork in the front of the case (which engages the planetary gear assembly to switch between high and low range).
Sorry don't see the significance of the link you posted "Stripes" ???
Apology not needed. It did make me smile in my hour of doomI apologize, it was for the people that didn't believe your description of the damage.
Possible but unlikely. The centering ball starts squeaking and then shortly after it locks up and does exactly what the pics show, explodes the left side of the case off. I don't see much if any damage to the trans.I agree if I had actually been driving the TJ I would have felt and heard this failure happening and perhaps had time to stop prior the the catastrophic detonation. Unfortunately being in the tow vehicle i felt and heard nothing.
The double cardan will be intact, it just won't move freely.Here are some more pics. I wont be able to access the hoist for another four hours to get better pics Looks like the Auto Trans is damaged. See image 3772
Neither the auto or the manual go in neutral, one in park (all the way forward for the auto illiterate) other in gear, both with t-case in neutral.Never really owning an auto anything for very long I would have thought it would have to be in Neutral to tow as well?
When they towed my hire car from a carpark at the Tijuana border they broke in and stretched the cable forcing it from P into N to tow it to the compound.
Unlikely.I'm starting to think it may have been a torsional vibration generated from the front uJoint behind the front diff. It was replaced recently with a part from Repco because I needed to fix it in a small town and could not source a Spicer one.
