Sent him a PMI just noticed you're in NZ. Maybe @Kiwi TJ has an idea where you can get a new, used, TC that wouldn't require shipping from the USA.
Hope you pack securely. Wouldn't want the TC to have any damage during transport.
Sorry to read about your troubles. Hope you get it figured out and are back on the road.
If you were inclined to flat-tow, I wouldn't let this stop you. For peace of mind it would only take a few minutes to disconnect the driveshaft at the front diff and secure it up out of the way. At that point the risk is eliminated.After seeing this… and reading that the front driveshaft can just suddenly decide to lock up. I decided against setting up my jeep to flat tow. I’d rather borrow, rent, or buy a trailer than to go through this!
Sorry for your terrible luck man, hope you at least are able to find replacement parts at decent cost with Black Friday coming along!
Does the tracking show how close it is?Im still waiting on some parts to arrive but have now disassembled everything.
The total damage list.
1/ Replace front drive shaft
2/ Replace Transfer Case
3/ Replace Rubicrawler transmission control cable
4/ Replace both axle ujoints
5/ Repair exhaust pipe (area close to front diff)
6/ Repair hole punched in floor
Thought some might like to see the destroyed transfer case
Very true… but question for you/anyone else that commented about the driveshaft locking up. Why isn’t the rear prone to it also? Is it because it isn’t double cardigan? My jeep has an SYE with a double cardigan for the rear driveshaft, so could it potentially happen to it as well?If you were inclined to flat-tow, I wouldn't let this stop you. For peace of mind it would only take a few minutes to disconnect the driveshaft at the front diff and secure it up out of the way. At that point the risk is eliminated.
The potential is there and it does and has happened. The difference is age and wear. The front shaft rarely gets replaced when a build is done so it has been in use and turning for much longer than the new rear that is swapped in for the SYE or even just a lift on the Rubi versions. The rear will lock up and destroy stuff in less time since it runs at a higher angle. The reason it doesn't is folks also maintain them better. This front that locked up has likely been in use since the rig was new and nothing ever done to it or even looked at.Very true… but question for you/anyone else that commented about the driveshaft locking up. Why isn’t the rear prone to it also? Is it because it isn’t double cardigan? My jeep has an SYE with a double cardigan for the rear driveshaft, so could it potentially happen to it as well?
https://4xshaft.com/products/double-cardigan-drive-shaftVery true… but question for you/anyone else that commented about the driveshaft locking up. Why isn’t the rear prone to it also? Is it because it isn’t double cardigan? My jeep has an SYE with a double cardigan for the rear driveshaft, so could it potentially happen to it as well?
Holy crap thats hilarious! I totally didn't realize my mistake. That made my day!
Mr. Rogers would be so proud.Holy crap thats hilarious! I totally didn't realize my mistake. That made my day!
Can you say “grenade the transfer case boys and girls?”
That is hilarious.
I did just this. On a trip the rear shaft DC started to make noise. I removed the shaft and continued to drive it in front wheel drive mode for a couple hundred miles. Then I flat towed it 1000 miles back home. That DC had only lasted about 20k miles.
HI Mr Blaine its been with NZ customs for 7 days. From memory it only took about 5 days to arrive in NZ. The police have just busted a drug smuggling ring at Auckland Airport. I think it was mainly baggage handlers so they are probably a bit short on staff at the moment. Once it clears customs it will take about 2-3 days.Does the tracking show how close it is?
I think the main reasons Double Cardans fail is lack of maintenance. In my TJ it is sandwiched between the bash plate and the transmission and very difficult to inspect without removing the bash plate. To remove the bash plate you need to support the transmission and transfer case so its not a two minute job. I always gave it the old wiggle test whenever I was in the area but obviously that is not good enough.Very true… but question for you/anyone else that commented about the driveshaft locking up. Why isn’t the rear prone to it also? Is it because it isn’t double cardigan? My jeep has an SYE with a double cardigan for the rear driveshaft, so could it potentially happen to it as well?
Fingers crossed everything arrives unscathed and you don't hop on a plane to come visit over the packing job.HI Mr Blaine its been with NZ customs for 7 days. From memory it only took about 5 days to arrive in NZ. The police have just busted a drug smuggling ring at Auckland Airport. I think it was mainly baggage handlers so they are probably a bit short on staff at the moment. Once it clears customs it will take about 2-3 days.
