Due to having many of my original ideas stepped on, ripped off, or just plain copied, I tend to support those who originate ideas. As such, Buchanan was the first to market with the seat riser for the 03-06 TJ. I use the ones that are 1" tall for all those that I do but again, being well over 6' tall may have some effect on my choices.Interesting. So it must have been the same time that Jeep switched to the high back seats in 03 that they lowered the seats? Funny because I'm only 5'9 but it's never bothered me and I don't think I ever thought of the seat as being that low. It would be interesting though to try some risers and see how I like it.
Be careful not to get them too tall as the streamer bar gets very close to the side of your head if you do.
Buchanan's are well made, high quality hardware,made from aluminum and more expensive than they should be. Avoid anything with a compressible puck. The bolts need to torque down tight and stay that way to keep you as safe as possible in a collision.
Might already have risers installed. Did you buy it new?Oh man, I had no idea. I am only 5'9 on a good day and to me it seems like the stock seats sit pretty darn high as it is.
1 1/4". Used some 3/4" ID, Sch40 Pipe and bolts 1 1/4" longer than stock, all Grade 8, plus washers.
Simple, cheap, solid.
I'm 6' tall and I hated the "look under the steering wheel" but my big reason was to raise my legs.
Forgot to mention that those of us who drove and own the 97-02's first really noticed it hopping into the later ones when we "fell" into the seat. It was immediate and obvious that they were much lower.
Apologies for correcting you twice but being a fastener nerd, I can't overlook that you mixed grades between Metric and SAE fasteners. Only one bolt per seat is SAE and that is the larger Torx head version while the other 3 are metric and to be Grade 8 equivalent, they would have to be Metric Class 10.9.
Yeah not my field of expertise. I just went to the bolt supply house and showed them the bolts, they gave me the same or better. I knew Grade8 was in there.
Big point is don't just use cheap hardware store bolts.
So after all of that, I am assuming that 1 1/2'' aluminum blocks or pads with some quality hardware should do the trick.
Jason
