I am regearing my Dana 30 after completing the rear a few months ago. This axle has been much more of a pain, I attempted to use shims behind my carrier bearing races like i did on my rear but quickly found out how aggrivating it was. I decided to pull the bearings from my carrier and use one of the old bearings and new races as a setup bearing. Without the shims under the new bearing races i had to cut the cages on my brand new Koyo bearing to use my bearing splitter on the race. I got my backlash (.008-.009) and pattern dialed in where i wanted it and setup the pinion side. I went to Oreilys and got 2 new bearings; they were chinese house brand. I wasnt thrilled about this but my local options are limited and i took off work today to get this done. I pulled my setup bearings and installed new bearings with shims used from setup and when i went to install the carrier it was way to tight to get fully seated. I pulled the carrier and measured the dimension from inner race to the top of outer race with it sitting on top. I could visually see that the race stuck out farther that when i tested it on my setup bearing side by side. I found that the outer race was .005 taller with the new bearings. I blamed it on cheap chinese bearings. Found a store across town that had Federal Mogul National brand bearings in stock and even though they are chinese still i had more faith in the name brand with 3 year warranty.
Started over by cutting another set of brand new bearings and removing them. Before i installed the National brand i put them side by side with one of the setup bearings i used and measured the height. They were much closer to the old Timken bearing i used for setup but still about .003 taller so i pulled .003 from the shim pack under each carrier bearing. I got the carrier installed and while it was still tighter getting in i was able to get the caps on and tight.
Now backlash is only .004. I am at a loss what to do and i really dont want to throw another set of bearings away.
Does anyone have any ideas to help me out. Does .005 of wear on bearings seem like alot? Jeep has around 160k on it.
