Last weekend I installed a 1.25 inch body lift and a pair of 1 inch rise motor mounts. Shifted fine.
Yesterday I installed my skid plate. Now the shifter is hitting when I try to put it in reverse. The tranny now is now sitting 1.5 inches higher in the rear than it was before plate install. I would figured if anything it would of thrown it forward instead of backward.
Is there a way to adjust it? For now I just removed the plastic trim and stuff which allows me to get it in reverse but I need to remove some more of it to make it work properly.
Any fix that you know of?
