Thanks for the input. Yeap I am aware that I will need some BS extensions. If I cut them exactly where they need to be, hopefuly I will not use any shock travel though.You are pretty much where I am at ride height, so the 55239's will work well up front, but you'll need to add 1.75" of bump stop extension up front. For the rear, you can run the 55241's, but you'd get a better travel bias if you run bar pin eliminators up top. That will give you a closer 50/50ish bias, but again, you'll need bump stop extension. You can forego the bump stop extension in the rear if you have a 1.25" BL. Otherwise, you probably need the rear extension anyway for the rear track bare relocation bracket to clear the tub.
It seems like I should wait a bit to listen to some real life opinions. That's the most difficult part... waiting.. haha
This is what i can tell you from my experience and echoing again...Mostly personal experiences, and opinions.
For example, I have seen many times in this forum that Bilstein 5100 are a stiff shock choice. I have seen that you suggest a lot Skyjacker Black Max Shocks, and that they are a bit softer than Rancho RS5000x.
I would like to know if anyone has personal experience, running both choices, or two of them in the same rig. And how they compare.
I most likely will go with the longer Ranchos, but I have some time to kill till then.
Out of the box shocks within a price of Fox downward...
Bilstein 5100's
FOX
Rancho 7000
Are by far the stiffest.
The Rancho 5000x is not as stiff as the above.
The Blackmax IMO is the smoothest of the bunch on a TJ.
Thanks, you've been very helpful in these threads.This is what i can tell you from my experience and echoing again...
Bilstein 5100's
FOX
Rancho 7000
There is no better/best here...everyone likes something different. A smooth ride to driver "A" might be mush to Druver "B" or too stiff or...._____ and vice versa
Which ones?I see the KYBs getting some attention on here lately. Where would you put them in this list of stiff-to-soft?
Which ones?
They have two sizes. One for the 3-4" lift range and one for stock.I can only find one size for the Monomax, and it's tailored to more of a 4" lift option.
The Monomax I can speak of ...Ah, sorry, I thought that @TJim had specified one in his OP. But @bobthetj03 seems to say that there is just one for a 4" lift. Maybe @TJim can answer.
I've spent hours pouring over all the numbers at shockwarehouse.com and did find a couple potential KYB Monomax fits. Although they weren't specific to the TJ, it looks like I could either add a bar pin to them, or run a bar pin eliminator. However, when I looked at the vehicles they fit, all were heavier full size trucks or SUVs. Somehow this didn't feel right though!They have two sizes. One for the 3-4" lift range and one for stock.
I'm willing to give it a shot. The risk is lessened by the fact that they're also offering a $35 rebate now. I'll definitely report back once I get my hands on a set!
You may have just sent me over the edge with that rebate! Damn you!I'm willing to give it a shot. The risk is lessened by the fact that they're also offering a $35 rebate now. I'll definitely report back once I get my hands on a set!
https://skyjacker.com/
Depending on how my KYB's run...I may be trying them out too!I'm willing to give it a shot. The risk is lessened by the fact that they're also offering a $35 rebate now. I'll definitely report back once I get my hands on a set!
KYB makes their own shocks...
The monomax is stout.
I'd say very comparable to the Bilstein 5100.
I'm not sure why yet, but I also noticed that, overall, the BlackMax shocks tend to have shorter compressed and longer extended lengths than other comparable shocks I was looking at. This really helped with my oddball setup. I'm not sure why that is, so I'm trying to learn more there.Depending on how my KYB's run...I may be trying them out too!
I'm just over 2". I'm also using the 0-2" 5000X shocks and they are at about 55/45 travel.Out of curiosity, do you remember how much actual lift did you get?
Can I order some from you and get a refund with free return shipping if I don't like them?The Blackmax IMO is the smoothest of the bunch on a TJ.
