That's probably a better solution.
We had some stuff down in the shipyard that we used on the parts we couldn't get to with a sandblaster and airless sprayer. IIRC it was called flocoat, or something like that. Nasty, smelly, sticky fluid that needed to be warmed up to apply. It was a brown, translucent color. Reminded me a lot of cosmoline. Anyway, you would flood the area that needed coating with this stuff, let it sit for a little bit to penetrate, and then drain it out before it got to cold to flow. Absolutely no corrosion on the treated surface, ever. You could never get it off of anything that it got stuck to, so your overalls were trashed and any tools that you used around it were permanently sticky and brown. I wish I had the NSN number for it. Now that stuff might be a corrosion prevention coating to look into.
