Shopping Around For Axle Shafts
Kon
Athens, Greece
Hi everyone,
I was browsing around the web checking out axle shafts for my Dana 30 front axle with an Eaton eLocker.
I know that it is suggested to use 30spline shafts for 35s (and probably 33s?) however, since I have recently installed a new carrier (Eaton eLocker) that works with 27spline axle shafts along with my wish to renew my 31s KO2s with a new set of the same brand and size tires does not demand 30spline axle shafts.
I have to say that I have no issues at the moment with my current axle shafts and the reason behind me shopping around is to be proactive and replace my almost 20-year old current set that has probably seen better days. Add to that the additional stress that they now experience when the axle is locked and it seems to be the right thing to do.
So far I have had checked out the usual brands (Yukon, G2, Alloy USA etc.) and was leaning towards this set;
Let me please know if there are specific things I need to pay attention to such as the alloy composition which is described to be different between brands (e.g. Yukon mentions 1541H while G2 mentions 4340).
Thanks!
Jerry Bransford
TJ Guru Moderator
Staff Member
Fleming Island Florida
Yukon is so fucked up if they're really making front Dana 30 shafts out of 1541H steel. 1541H is only used for the rear Dana 35 axle shafts where Wrangler axles are concerned. For the front I'd go 4340 Chromoly. Revolution Gear has them. Yes 1541H is slightly stronger than the carbon steel OE shafts were made out of but not by much when they're only 27 spline. The Super 35 shafts get away with 1541H steel because they're 30 spline replacing the OE carbon steel 27 spline shafts.
SvtLdr
Search Engine Certified Mechanic
NE Indiana
As Jerry mentioned, Revolution Gear is highly regarded around these parts. They offer a couple options in the 4340 variety.
NskLJ
Long Beach
Thanks @Jerry Bransford. So I guess that the main criteria I should look for should be 4340 alloy and cromoly? Regardless of brand?
Revolution gear is back ordered on the stub shafts for the Dana 30. I have ordered axles last month and am still waiting. I spoke with them earlier this week and they were supposed to be in this week but I have not heard anything yet.
sourbluff
Missouri
Isn’t just the Dana 30 stub shafts. I ordered Dana 44 front, rear shafts and install kits from a 3rd party vendor in November. Just got rear shafts on Friday. Front shafts are showing Feb ship date, fingers crossed. Install kits were cancelled as was no estimated ship date from Revolution. Oddly enough my gears I ordered from Amazon at the same time shipped in like a week
I’m not knocking Revolution and personally plan to reorder install kits and wait as like OP my current setup works. Every Jeep should have a pending parts pile right 😉
Reactions: SvtLdr and NskLJ
Kon
Kon
Athens, Greece
Thanks everyone. @Jerry Bransford Your suggestion to avoid 1541H alloy and go for 4140 alloy (I understand it's the equivalent of 4340 for rear axles shafts?) would be the same for the rear Dana 44 as well?
TJim
Athens, Greece
Yeap! 4340 for both Dana 30 and 4140/4340 for Dana 44. 1541H is only for Dana 35.
27 splines inner/ 27 splines outer for Dana 30, and 30 splines for Dana 44.
Reactions: Jerry Bransford
L J
Ranchos aren't real
Dumont Dunes
I'm running Revolution 4340 front / 4140 rear axles in my LJR with Dana 44 front / Dana 44 rear.
Kon
Kon
Athens, Greece
Yeap! 4340 for both Dana 30 and Dana 44. 1541H is only for Dana 35.
I do seem to find 4340 for the rear Dana 44. I see 4140 instead. Do you know if it's the equivalent?
Kon
Kon
Athens, Greece
I guess that replies to my above question on 4340 being the equivalent to 4310 in front and rear respectively.
L J
Ranchos aren't real
Dumont Dunes
I'm not sure about other suppliers but Revolution spec'd 4140 for the rear due to it's slightly different properties from 4340.
Kon
Kon
Athens, Greece
May I ask where did you install the eLocker in Greece?
Also, where did you buy it from? Did you order it straight from the USA?
Yes, ordered from quadratec.
I installed it in the garage where we service all cars of my family. Not one of the jeep-specific shops, just a general garage though I know and trust the two brothers who have it and believe them to be good mechanics. It's in Glyfada where I live. PM for details if you want.
Reactions: TJim
NskLJ
Long Beach
I do have my install pile in the garage also. Are you looking for install kits for Ring and Pinion sets? You could always piece those together, bearings shims, seal and crush sleeve.
sourbluff
Missouri
I’m still saving pennies for big brake kit, waiting on front shafts and for my brothers garage to be finished so I’m in no rush.
