TJ Fest 2021
Should I buy a JKU with the 3.8?
Hobbes62
Winder GA
Wondering if I should consider purchasing a 2011 JKU with 30,000 miles? Would be for the wife. If so how much? I think I could snag it for 15K. Has 3.73 gearing on it, Probably needs 5;13s. I am worried that the gas mileage would be terrible (Wife would daily drive it). Thoughts?
billiebob
Kootenays, BC, Canada
The 3.8 is not one of the better engines but price, mileage and condition like this... I'd buy it.
How many miles will you put on? The 3.6 is only a bit more economical. No Wrangler will reduce yer gas costs.
Reactions: Hobbes62
Hobbes62
Hobbes62
Winder GA
Would probably get 10K miles a year. Thinking it may be a good deal for the price.
02GreenTJ
California
I know many people with the 3.8 that are happy with it. The issue comes with the automatic transmission. If it has a manual it is even more desireable. That said with that amount of miles I wouldn’t hesitate.
Reactions: Hobbes62
Ct_tj
Brookfield, Ct
I see no reason to avoid the 3.8. My best friend and my dad both have jks with the 3.8, both problem free. A lot of my customers that have the 3.6 have had tons of tiny little problems that add up to a big headache. Not to mention the oil leak issues..
  • Wow
Reactions: TJ2 and Hobbes62
pagrey
Los Angeles, CA, USA
I've heard oil consumption on the 3.8 is normally over a quart every 3k on young engines. Epic turd is a really great description. Do a little research into people replacing those engines, it should scare you off.
Reactions: Hobbes62
Hobbes62
Hobbes62
Winder GA
That's what so interesting seems like its a 50/50 split on the oil consumption issue. Seems like something to ponder. I have spent time in the seat of the 3.6 auto. Really liked it.
Alex01
Enthusiast
Martinez, CA, USA
I drove a 3.8 jku when we rented one in hawaii. It was fine except when we took it to the summit of Mauna Kea (13,000 ft). At that altitude I had it floored just to get up a slight hill. At sea level it was very liveable.
If the price is right take it for a test drive and see what you think. I would drive both though just so you can make a more informed decision.
Reactions: Hobbes62
Ct_tj
Brookfield, Ct
The 3.6 is a nice running engine, but problem filled. The early ones had misfire issues on one of the banks causing cylinder head replacement (recall). There is no doubt that the oil cooler gaskets will blow out way sooner than they should, that's another $700-$1000 depending on the shop if you dont do your own work. Not to mention the horrible valve train noise that could start around 30k miles for no reason at all. Sounds like the engine has no oil in it.
Reactions: Hobbes62
TurboTJ
Walnut Creek, CA
I've got 60k miles on the 3.6 in my 2014 Grand Cherokee. It seems to be a fine engine. I have had zero problems with it.
Reactions: Hobbes62
zebra12
2005 TJ Unlimited Rubicon
Corvallis, OR, USA
I had an AWD Journey with the 3.6 and have a Grand Caravan with the 3.8. Not exactly an apples to apples comparison, but the 3.6 feels like it is a race car engine compared to the 3.8.
oldjeepman
Nebraska
If you can find a 2012 or newer, better engine and the interior was redone in 2012.
