Q: Should I install a dropped pitman arm?
A: NO! Whether or not you need a dropped Pitman arm is nothing more than a geometry issue. (i.e. Only if you changed the geometry of the steering is a dropped Pitman arm needed to correct for that geometry change.)
For the typical lift heights installed on a TJ, like up to about 5 or 5.5" inches or so, you should not install a dropped Pitman arm unless you also installed a dropped upper mount for the trackbar.
Aftermarket dropped upper trackbar mount installed = a dropped Pitman arm is needed.
Using a factory upper trackbar mount = the OE factory Pitman arm is needed.
Very few other times would a dropped Pitman arm be needed and those don't occur until you get to around the 6" suspension lift height. Installing a dropped Pitman arm any other time is just going to cause bump steer.
So while a dropped Pitman arm is generally always needed after installing a suspension lift onto a CJ or a YJ, rarely is one needed for a TJ due to the TJ's improved steering geometry design.
