I understand the difference between winching and hoisting. It seems a simple enough winching maxim to say, "Pay attention to the breaking strength of your winch rope and the load limits of each component as affected by the manner in which each component is being used and remember that the system is no stronger than the weakest piece." However, the fact that shackles, hooks, etc. have designed safety factors in excess of marked working load limits seems to be mentioned in every winching thread and the implication is frequently that winch rope breaking strength and stamped WLL markings can be exceeded with impunity because of those safety factors..
If design factors don't apply to vehicle self-recovery with a winch why are design factors always mentioned? Why are these safety factors mentioned by companies in the winching business who we should expect to be able to rely upon as experts? That's what confuses me.
No one is or should be saying to disregard any strength ratings with impunity. It is about education and understanding. One should not call for strict adherence of overhead lifting WLLs to a device or appliance to be used with a winch and only use those on one side of the equation.
If you are going to apply a overhead WLL with a given safety factor to a hook, then you have to do the same to the line and the winch. The issue is parity and the understanding that there are different ways of rating how much load something can handle and if you are going to use them, then you should use them across the board.
It is lopsided to hold a hook or shackle to overhead lifting standards of 5-1 if you are using it on a steel cable that has slightly more than a 1-1 safety factor. The standard steel cable is 5/16" with a breaking strength of 9800 lbs. and is frequently supplied on 9500 lb. rated winches. The standard anchor shackle is from the overhead lifting industry with a safety factor of 5-1 and a rated WLL of 4 3/4 tons which is 9500 lbs. Someone, somewhere, picked a shackle size based on a comparison of those two numbers and bam, it became accepted as the standard with no understanding of how lopsided the two ratings are and why they are the way they are. At no point should something breaking at 9800 lbs. dictate that anything else used with it need a breaking strength of 47,500 lbs. It just makes no sense and it is too lopsided to be sensible when that starts to dictate ratings of the rest of the gear used.
You bring up a point that really needs to be understood. Why do the companies we are supposed to be able to trust build a winch with a 9500 to 10,000 lb. rated pulling capacity supply a cable that is rated at 9800 lb. breaking strength? How does that design factor apply? What is it they know that we don't? Why can they get away with such a small difference in rated pull design factor versus the design factor of the line's rated breaking strength and the incidence rate of that being a problem is so low as to be statistically unaccountable?
You've been around long enough to know that the hook in question was the standard hook Warn supplied on all of their 5/16" lines. Why did they do that and how could they have possibly gotten away with a hook with a 3/8" pin through the clevis and no thimble to protect the minimum radius of the cable to prevent damage there? We are supposed to trust them to know, so what do they know that we don't? It was obviously determined somehow that it would work and not endanger the user and subject Warn to the liability of it not working, so what do they know?
That answer determines the suitability of the rest of the ratings and the parity thereof, so, what do they know that we don't?
