Should my front drive shaft be spinning when in two wheel drive? It spins and makes this clunking noise, should I get it fixed or is it normal?
Should spin, but there should be no noise. Several culprits but first, if you get under the Jeep, with the tranny in neutral, there should be zero play anywhere in the driveline.It spins and makes this clunking noise
problem, fix itI could rotate my front drive shaft maybe 1/8th to 1/4 inch
problem, fix it
I could move it slightly by hand, is it a major problem?
Nope, that's a normal amount of back lash. If you really want to think you have something fubar, put a Detroit up front. About a half turn is normal with those.problem, fix it
Okay, so I have nothing to worry about? It just sounds like it shouldn’t be making that noise, I will check it when I put it in neutral to see if it does it, I know it has no noise when in 4wdAbsolutely not. The teeth of the gears need a little space between each other to allow gear oil to do its job and for the gears to thermally expand when they heat up (there are also a few other uses for backlash as well). The front driveshaft is basically disconnected from the driveline at the transfer case while in 2wd so the only thing holding the driveshaft in place is the tires. The little you can move it is just the gears coming together within the diff.
Thank you very much! I appreciate all the help!Nevermind the rotational movement. Like others have stated, that is the normal play in the gears. I would try moving the shaft up and down / side to side.
Look for movement where the the pinion shaft exits the front diff. Then look at the front u-joint, the slip joint on the driveshaft, at the rear double cardan and where the front output shaft exits the t-case. I wouldn't worry much about a tiny bit of movement in these areas, but if there is anything more significant, I'd start investigating further.
