Absolutely normal. The oil pump is mechanically driven by the engine so the oil pressure goes up and down in step with the engine rpms.
Mine does the same thing.
X whatever. Perfectly normal.
Yes, newer TJ oil pressure gauges were reprogrammed to remove the normal ups & downs of oil pressure. So long as the actual oil pressure is within normal limits, the gauge is programmed to stay at its mid-scale position.
This was done because too many new Jeep owners buying the new TJs were complaining about the oil pressure going up & down & the dealers couldn't convince them it was normal. They were the ones buying their first vehicle with a real oil pressure gauge & they were ignorant of how they are supposed to work. The factory was forced by all the dealer complaints to program the normal ups & downs out of the gauge and present a steady mid-scale reading so long as it was actually ok.
HOWEVER, the Oil Pressure is still fluctuating and dropping and bouncing back up quite a bit. .
I reset the ECU by Disconnecting the battery for 15 min as I forgot to do so after replacing the sensors. That made a big difference. No Check Engine Lights or Irradic Idling (still seems a little high on start up and does fluctuate a few hundred RPM still) HOWEVER, the Oil Pressure is still fluctuating and dropping and bouncing back up quite a bit. I Am beside myself as to what could be causing this problem. The Oil pressure sender is from Napa, so Its NOT Mopar. Maybe its bad, so I guess I have to rule that out. Any OTHER Ideas?? I really hate to replace the Oil Pump since my pressure was really good the TWO times I hooked up a Snap-On Mechanical Gauge and ran it for 20 minutes each time.
Wow...Relax Mr. Trail Yacht; What do you have to prove? Let me be more specific. I hardly think its 'NORMAL' for the Gauge to drop to ZERO (not mid-range lows) intermittently, the Red CHECK GAUGES light to come on with a concomitant BEEP BEEP BEEP that all of a sudden started happening that has never happened in 15 years prior??
Nope.I always thought that 1200-1300 rpm at start up was to lube the cylinders and cam.
While it's no longer the case for all or even many vehicles any more, engine designers sometimes set the cold engine rpms to be a little higher to help the engine warm up more quickly.Why then?
I would guess that unplugging the sensor would simply cause the gauge to read zero. As for online parts, look at www.wermopar.com, www.moparpartswebstore.com, or www.wholesalemopar.com.Just curious if some can tell me what I should expect the gauge to do if I unplug the oil pressure sensor wire while the engine is running assuming the sensor is functioning properly...
Where is the best place to buy mopar parts online?
From a cold start I use a 30 second rule. 30 seconds is plenty of time for the oil to make its way through all the journals.
That is also temperature related. At 40 below and not plugged in every vehicle I've owned starts with no oil reaching the tappets. You listen to the tappets clattering for a minute or two even if you use synthetic oil. Then you drive a couple of blocks on the tire flat spots before the rubber starts flexing and the ride smooths out. And another 5 miles before you feel any heat from the defroster.Similar type question I've always had is this:
When you start a vehicle, should you wait till the oil has had some time to get dispersed? Or just take off? I usually use my RPM's as a gauge to when to put it in gear to go. When you start they're like 1200-1300 and then they settle to around 800-900. That's when I go. I just reasoned that since starting the vehicle is the hardest thing on the engine then I should give some time for oil to get throughout. May not matter though???
Isn't this true for the other gauges as well. They stay centered; only moving to the right or left when something is not normal?
