Should the slip joint on my driveshaft look like this?
Cletusthejeep
Hot springs Ar
I’m pretty sure this isn’t supposed to be like this. Anyone know what going on? And any advice on what to do about it? Im thinking the drive shaft is to short? But I don’t know
Cletusthejeep
Cletusthejeep
Hot springs Ar
Well I’m just trying to diagnose a noise it’s sounds similar and feels similar to a ujoint so
I thought maybe this might be causing it?
toximus
TJ Expert
Northern WI
Is it just the perspective or is the exhaust mounted to the body? If you move the mount to the frame it'll be a little quieter.
Steel City 06
Pittsburgh, PA
Try removing the rear driveshaft (be sure to use the parking brake while you're removing it) and going for a ride (use 4WD) to see if the noise still exists.
If it does, put in the rear shaft and remove the front.
If one driveshaft out eliminates the noise, then you know where the noise is coming from.
Cletusthejeep
Cletusthejeep
Hot springs Ar
Wow I never thought of this😂 but it makes total sense! Thanks👍
Reactions: Steel City 06
JEEPCJTJ
Half way between Pittsburgh and Cleveland
I haven't had to pay any attention to my rear driveshaft the dozens of times I've been under there but I would think there should be some kind of seal to keep the grease in and the gritty stuff out. I'd also jack up the Jeep by the back bumper until the tires were off the ground and see how much more of that blue spline would be showing at that point. I think it's too much already.
Brian83
Oklahoma City, OK
up to 2" at normal ride height is fine of the blue teflon coating, at full flex it can be about 4" and still be fine. And no seal needed.
mrblaine
TJ Guru
Quail Valley, CA
There is a seal there. It is spline shaped and sits inside that cap that you see on the end of the pinion yoke.
