SJ’s TJ
I got a little more time in the garage today. Got the front of the frame chopped off:
For a little fun I pushed the LS into place on the stand:
what a freaking beast! I love LS swapped TJ's
Much appreciated. I just need to clean up the frame a little to get the remains of the old upper CA mounts off that section and then I can get the front half kit mocked and tacked. Once that is done, then I'll finish weld it and start working on motor mounts and motor placement. Exciting stuff!!
I’ve got the motor mounts finished welded. I still need to box them in, but they are good to go for now:
I started looking at the trans mount and my existing universal trans mount is off by about an inch:
You can see that it’s just off. I thought about trying to create a plate that would bolt into both the trans mount and the crossmember, but the bolts are covered by the DOM of the crossmember.
