I have a 2000 TJ and I'm looking to install a 2" Skyjacker spacer lift . I'd like to put 33 on it , just want it for looks and will be doing no off-roading . Friend has it on his 04 , any input would help greatly. I'm new to owning a Jeep
So with thatWith 33" tires you'll really want something closer to 3" or more of lift in order to clear the 33" tires and look good.
33" tires will indeed fit with a 2" spacer lift, but it might look a little tight.
Thanks RobLots of people use spacer lifts, super common. Skyjacker is just one seller of such kits. A 32 would definitely fit better but you will still need to bump stop it correctly. Depending on wheel back spacing, you may need to add a washer or two to the steering stop to prevent rubbing at full lock.
Add the spacer lift and a 1.25" body lift and you're good to go with 33's and no serious off-roading.
