Smaller Diameter Rear Shocks
Mark K
Lifetime Supporting Member
Texas Hill Country
Howdy. Things are tight in my TJ's back end. GenRight extended range tank, larger cast iron diff cover (diff turned up to match angle with the double cardan rear shaft), Banks Monster exhaust. I've just found that the Banks pipe is too close to my right rear Rancho RS55240 shock. A smaller diameter shock would help. I like the Rancho ride, going with the H&R springs. Can any of y'all recommend a smaller shock?
Mumblewood
Renton Wa
Shave the exhaust where it hits, take that part you shaved, flip it inside out and re weld it back into place, that’s what I did with my spintech, it worked
L J
lightbars before lockers
TJ Jim
Tennessee
I’ve got the Jeep with three cats. To get my tailpipe off the shock I loosened the two bolts just aft of the cat, stuck a 2”x4” between the shock and the tailpipe, and tightened the two bolts back up. Problem solved in ten minutes. Don’t know if your year Jeep has the same ability somewhere along the exhaust pipe?
Reactions: SvtLdr
97TJNM
High Desert Redneck
Los Alamos, NM
My exhaust was touching the plastic dust boot/shield thing on my Rancho shock after my lift. Cut the boot off with my pocket knife, no more interference.
Reactions: TJ Jim
Mark K
Mark K
Texas Hill Country
BlackMax shocks are smaller and can be run inverted if desired.
Solid info, gents, thanks much.
DougyintheBushies
Chickamauga, Ga
I’m not exactly pleased with my Ranchos ride quality. I know they are better than the clapped out p. o’’s RC shocks they replaced but I wished I went with black max.
