Smittybilt tow bar
Sandcrab
Texas
Anyone here ever flat tow with a Smittybilt tow bar. Thinking about buying on.
Jerry Bransford
TJ Guru Moderator
Staff Member
Fleming Island Florida
Thanks for the reply. I have never flat towed. What didn't you like about.
Plenty of people flat-tow their TJs without problem. You only need magnetic tail lights, shift the transfer case into Neutral, and the transmission into Neutral or into any forward gear to prevent it from being spun without adequate lubrications.
LakeBeard
La Habra, Ca
No real issues, more of a preference. I think the main issue I had was not being able to back up unless having someone with me.
06lj
Arkansas
I have the Curt bar which is about the same. It works fine. I installed the Hopkins wiring kit for the brake lights. It was simple and easy to install. For braking I have a brake buddy. It keeps me legal but isn't the greatest system for actual braking power. I drive it real careful when using it. I've used the tow setup a few times but also am not a fan. For longer trips I just rent a trailer.
Sandcrab
Sandcrab
Texas
Ok well I think I'm going to try it. Did you have brake activator for your tow vehicle. Do I really need it.
LakeBeard
La Habra, Ca
I don't have one for the Jeep, in Ca you do need one, not sure about other states. I think it's like 2k and brakes are required. Not 100%
Sandcrab
Sandcrab
Texas
Thanks for the reply. Going to be pulling 500 miles one way. May have to look into this a little more. I would have to rent a trailer
Sandcrab
Sandcrab
Texas
What about brake system. Thoughts
cherrybomb
Texas
I'm pretty sure here in Texas it is over 4500# you need brakes, so with a TJ you are under that limit. I doubt anyone is going to weigh you and with a class A you won't even know that thing is back there
Sandcrab
Sandcrab
Texas
Thanks for the information
Reactions: 06lj
