TJ Fest 2021
Soft top or hard top?
teagan_tj
roseville
hey everybody its time for me to get a new top for my jeep i currently have a soft top but i need to get a new one. I cant decide should i get a soft or a hard top? feel free to leave links to tops you recommend.
tworley
Bent Currie Club
Morrison, CO
Stick with a soft top. Easier to remove, store, and IMO just as quiet (or loud?) as a hardtop. Bestop is the go-to brand and OE manufacturer.
DaveC
Gilbert, Arizona
I originally wanted a hard top; my TJ only came with a soft top. Figured I'd give it a year before pulling the trigger on a hard top and now I don't think I ever will. I can run with the top up/enclosed, top down, top up with windows out or any combination with the sunroof flipped back (I have a Bestop Supertop NX). I've figured out a pretty simple system to load and organize my hunting gear in the back without having to unzip the rear window, so not having a flip-up hatch like a hard top has become a non-issue.
I didn't expect the TJ to be as quiet as our DD vehicles (2005 GMC Sierra and 2015 Nissan Altima), but it's not that bad either. At freeway speeds, I can still have a conversation with the passenger or hear the stereo just fine. At less than freeway speed, it's really hardly noticeable. I have one buddy with a YJ with a hard top, and it's noisier than my TJ with soft top. Another buddy has a 2019 JL with hard top, and I was shocked at how noisy it is (louder than my TJ).
For me, the benefits of the hard top (slightly better insulation in the summer months and minimally additional ease of cargo access) aren't enough to outweigh the inconvenience of taking it on/off and storing it when off.
If you do decide to go with soft top, go with a Bestop, as the quality of the top will be a big factor in whether or not it lives up to expectations
Cedar128
New Jersey
For only one top go with a soft top or you'll regret it when you see everyone else riding around with their tops down.
Reactions: Web98
T
teagan_tj
roseville
thank you so much for the in debth cause i was thinking about noise and space for my fishing/ hunting gear also i will 100% be checking out the best top!!
Reactions: DaveC
Goatman
TJ Expert
Upstate NY
I'll try and muck up the thread. Depending on where you live, having windows you can see out of, and able to scrape down and frost off would be my main concern. And I think everyone here knows at least one person who got robbed when some asshole cut through the fabric to get in to the Jeep.
I've never had a soft top that actually kept all the rain outside the Jeep. Half doors that bend open a bit on the highway. Roof fabric stretched low with an iceberg on top. And the possibility of ripping as you try and remove that 25 lb ice block.
If you live in the south or west security is still an issue. I know people that got looted in their own driveway as they slept. Wake up and find a big slash in the soft top. Or at the mall, or work.
If none of these are a concern to you then go for the soft top. Best is to have both. You can always remove the rear glass of the hardtop in the summer if you are happy with a targa top.
Reactions: 04solartj
Apparition
TJ Expert
Twin Cities, MN
yall have convinced me soft top it is!!
Since you live in Minnesota where it’s 9 months of winter I’d consider a hard top if you drive it year round.
If it’s not your primary vehicle then get a soft top.
Ideally get both at some point.
glowell222
Northern VA
Well, I have and recommend both.
My soft top is a Quadratop from Quadratec that works with the original frame hardware. it's definitely not high quality, but it was certainly cost effective and keeps the rain out and the a/c in, when necessary. I also have quick disconnects for the frame bows so I can remove it quickly.
The hardtop goes on in November, and it is much warmer and quieter than the soft top despite what others may say, plus I like the rear window defogger and rear window wiper/washer for those nasty days after snow. I built a storage dolly out of some extra 3/4" plywood, extra 2x6, and some casters, two of which lock. I line it with a Phineas and Ferb blanket that usually sits in my cold weather kit. This allows the top to be stored in a vertical position, and it takes up the space of a very small couch-I still have plenty of room to park the Jeep in the garage in the same bay.
I have a remove-a-top hoist system that I bought from Quadratec a long time ago (before the JL was released), and that allows me to single-hand the top removal.
The soft top goes on in spring, dependent on how the weather of that particular spring turns out.
WallyWest
PA
I've heard the twill soft top from Bestop is actually quieter than the hard top. And very durable. But also expensive.
Don't have one myself, that's just what I've heard.
Steel City 06
Pittsburgh, PA
For me it was. Once I fully insulated the hardtop, then the hardtop was quieter. But uninsulated, the Twill was quieter.
Starrs
TJ Expert
Indiana, United States
Do you have somebody that is dedicated to help you remove the hardtop every time you want it off? I see no reason to own a hardtop anymore after all the jeeps I’ve had. Bestop Black twill would be the only top I would own for a tj. If you have to be worried about somebody slashing your top to rob you I would think they could also break glass to get into your jeep if you ran a hardtop. You cant worry about what if’s. Soft top is an all season top and a 1 man operation.
Reactions: Cedar128
Apparition
TJ Expert
Twin Cities, MN
Reactions: InOmaha and J R
Irun
Jeep Addict
Virginia
I was originally skeptical when I replaced a soft top recently with one of these.
However, after receiving and installing it, I'd do it again. As is always the case, do your homework before buying!
03sahara
Québec
Like most people are saying it depends on your plans here in Canada I put my Jeep away in the winter so I like to put the hardtop when in storage. It’s also nice for the spring and fall when the temperature isn’t quite warm enough to put the top down. I also think the hardtop is quieter than my oem soft top but It’s old and I’m about to replace it.
InOmaha
Omaha
My neighbor has a hard top lift in his garage. He can get his top off and stored away before I can get my windows unzipped. He can definitely put his back on faster. He has a soft top hanging along the wall he doesn't use.
I live in a generally safe area and park inside. So I don't worry too much about the soft top. I'd like a hard top, but LJ tops are few, far between, and expensive. I have other priorities.
