TLDR - Looking at repairing/replacing current OEM soft top - Pros/Cons of Fastback style soft top vs Traditional square style top, and/or any repair options for existing top.
2004 LJ (Unlimited) 95% pure trail rig - Our original OEM soft top is reaching the end of its useful life. We remove side windows and roll up back window when on the trail, but need it watertight while towing it (on a trailer) to the trails.
Basically looking for the least expensive option to keep it watertight/dry while trailering and easy to switch to (and back from) solid top only on the trail. No real consideration needed for daily driver, on road issues like road noise, visibility etc.
Current issues:
Need replacement back window - plastic cracking and zippers getting almost unusable.
Side windows getting increasingly harder to re-install.
Fabric still OK but due to age expect it to start having issues.
Looking for repair/window replacement solutions I have found they are limited for the LJ's:
Very few original OEM parts/windows available in the market.
Aftermarket options also limited to fit original OEM LJ frame - like no clear rear window available (only tinted) etc.
I have about decided it is time to bite the bullet and replace the entire top with aftermarket frame/hardware etc. so we can get options we want and future replacement/repair parts more available. The problem now is what is best option and first decision looks like a "Fastback" style or traditional full frame square type. We like the look of the fastback and they are less expensive due to lack of needing frame/hardware. What are the downsides of Fastback style? Is the loss of cargo space significant - we have a rear cargo locker and use the top of it for cooler etc.? What Brand/Model would you recommend? If traditional better what Brands/Model recommended?
Any opinions based on personal experience, and/or solutions to our current issues, greatly appreciated!
Thanks
Current issues:
Thanks
