California Sold
Looks like a deal. Good luck with sale. $18k in parts....
Seats look mint, are they original?
1998 TJ, 147K miles on odometer, I am the third owner by title, but the second owner just parked it.
Blaine Custom Build – everything you need – everything done right – all the little details you would expect from a Blaine build. Originally built for Robert Yates (friend of Blaine’s) – I’ve included the build link from Jeepforum. Jeep runs strong, drives perfect, stops on a dime, and will do any trail you would want to do (and has probably already done them). Not cosmetically perfect, scratches, minor hood dent, paint crazing on hood, etc.
  • Clean title in hand – originally purchased at Donavee in Fullerton – CA Jeep – no rust
  • 4” Blaine/Savvy mid arm 4 link front and rear custom suspension
  • Currie/Rockjock springs front and rear
  • Fox 2.0 reservoir shocks, outboarded rear, tuned by Wayne at Alltech
  • 12” of travel front and rear
  • Aluminum rear control arms, chromoly front – fully Currier/Rockjock Johnny Joints
  • 1.5” body lift – body mounts removed and welded higher on frame
  • Swayloc – front
  • New 315/70R17 (35”) Goodyear Territory Tires – less than 200 miles wear (5 new tires)
  • New Mammoth Boulder wheels – 17x9 – no rash or marks
  • Jeep OEM hardtop with Boom Mat headliner kit, wiper, washer, defrost all work and tied to factory switches (Jeep was a factory hardtop Jeep)
  • LED headlights, LED bulbs in taillights and interior lights
  • ORF interior cage with front and rear braces and custom floor tie in kit
  • Termotech insultation under carpet
  • MORryde/Exogate Spare Tire carrier
  • 2004+ TJ front seats, 1.25” riser
  • Factory rear seat with Bestop cover
  • Factory AC blows cold
  • J&M Industries onboard shower/heat exchanger – all hoses and pump included
  • Savvy Armor
    • Front aluminum bumper with hard core upgrade corner guards
    • Winch guard with custom flat tow bracket
    • Warn 9500XP winch, synthetic line, Safety Thimble 2
    • Aluminum Rocker guards with steel slider and internal brace
    • Aluminum Rear corner guards with rub rails
    • Aluminum Rear tailgate skin
    • Fuel Tank Skid
    • Belly up skid with custom engine skid
    • Currie rear bumper, reinforced/frame tie in with custom hitch
    • All aluminum treated with Sharkhide
  • Front HP Dana 30, ARB locker, 4:56 gears, fully trussed and fully sleeved by Blaine, Barnett diff cover, Warn small hub conversion with 3 Warn spare outer hubs, and 2 Warn spare inner assemblies, Warn Chromoly inner/outer axles, CTM U joints
  • Black Magic big brake kit for 15” wheels front axle
  • Rear Dana 44, ARB locker, 4:56 gears, disc brake conversion, Alloy USA chromoly axles, Barnett diff cover, full set of spare OEM axle shafts with backing plates pressed on
  • PSC Hyrdoboost steering and master cylinder, PSC ram assist, Currie Currectlync steering, Currie track bar
  • Factory 32RH automatic – rebuilt by Joe at Westminster Transmission with heavy duty/ 1 ton internals.
  • Temp guage in Tuffy center console
  • Dual coolers a stacked plate pass through in front of radiator, Setrab FP224M222 fan unit under tub with manual cutoff switch
  • Factory 231 with 4:1, SYE, JE Reel custom driveshafts, Savvy shift cable
Engine – 4.0 factory block with mods
  • Hesco Aluminum head milled to just under 10:1 compression ratio.
  • Hesco pushrods
  • Hesco H264 cam
  • Harlan Sharp roller rocker kit with high perf valve springs
  • Late model intake manifold swap
  • Load tuned on a Dastec dyno using a Unichip.
  • Measured improvements on a dyno. 27 HP, 35 lb/ft torque increase at rear wheels with 35” tires and 4:56 gears.
  • Fully ceramic coated, modular exhaust system
  • AEM cold air intake with new filter
  • Passes California smog
  • John Lemieux at All Four Wheel Drive did the work
  • Kenwood KIV-701 radio
  • Arc Audio Amp, XDi804 – 480 watts, 4 channel
  • Arc Audio subwoofer in Tuffy Security center consol
  • Arc Audio speakers, tweeters, in pod behind seats and dash
  • Switchpro SP9100 controlling ARB compressor, lockers, all lights
  • Rigid front light bar
  • Rigid amber rock lights
  • Amazon pillar lights on @Fluxor aluminum mounts.
  • Spare Parts (a ton, but here are the highlights)
  • 3 Warn small hub replacements
  • 2 Warn inner hub replacements
  • ball joints, TRE, bearings, yokes, etc.
  • 2 aluminum control arms with Currie JJ ends
  • Tommy Lee steering box spare
  • Green Machine high output alternator spare
  • spare Dana 44 gear set
  • spare hydroboost hoses
  • Factory side mirrors (Jeep has newer style OEM TJ mirrors)
Suspension build thread - https://www.jeepforum.com/threads/g...ort-arms.1076868/?nested_view=1&sortby=oldest
Engine detail - https://www.jeepforum.com/threads/aluminium-cylinder-head-for-the-tj-4-0.462155/
Oil cooler link - https://jeepspecs.com/models/jeep-wrangler/jeep-wrangler-tj/engine-cooling/
Nice Jeep. Agree with other posts that price is more than fair for an excellent turn key TJ. Question re T-case: Ad says 231 4:1?
Reactions: Apparition
it was built by the guy that does it right every time.
Sortof. In a moment of weakness, Robert let Stu talk him into that Toys by Troy suspension nonsense and due to time and money constraints, we fixed it up as best we could without completely starting over and gutting the entire suspension out from under it. I would never use a rear truss like that otherwise. We did however, manage to get it a whole bunch better than it was.
Very nice Jeep, good luck with the sale. Lets see some more pics of that GNX parked in front of it!
