I'm not sure what I hear. Some wind?
Stox5225 has a good idea.
The noise seems to get quieter when applying the brakes. Then starts back again when I accelerate. It did pull to that side before the brake pads were changed a few months ago but now it does not pull to that side, at least not bad enough that I notice. I'll check tomorrow. I'll also jack it up and move the wheel around.Well, if it accelerates when you do, then it’s 2 quite possible, and easy to check things. U-joint (which doesn’t require jacking it up) or the wheel bearing.
Notice any drag when you hit the brakes? Or any pull to that side driving straight?
Jacked it up this morning to wiggle the wheel. No noticeable movement horizontally but vertically I do hear a veryslight movement in the hub but the wheel doesn't really move or anything like I've seen in videos.
I'm so stupid, I have a floor jack but haven't been using it because when I replaced my control arms it wasn't tall enough to flex the suspension all the way down. It was just habit to grab the high lifter after that for the jeep.Oof. That’s brutal man. Yeah I only use floor jacks lol. Or an actual lift on post if I have to rotate tires.
