Im looking to upgrade my rear from a Dana 35 to 44 and do some regearing. Can anyone recommend a good shop to do the work? Thx!!
If you get a Rubi 44 you can swap it yourself. Its bolt in.Im looking to upgrade my rear from a Dana 35 to 44 and do some regearing. Can anyone recommend a good shop to do the work? Thx!!
Thx. And I agree, though id need some help to make sure i order it correctly. But i also need the front end regeared and no way can i take that on.If you get a Rubi 44 you can swap it yourself. Its bolt in.
Just to clarify, it would be a junkyard Rubicon Dana 44 from a 2004 through 2006 Wrangler Rubicon.Thx. And I agree, though id need some help to make sure i order it correctly. But i also need the front end regeared and no way can i take that on.
I see this is a few years old...what did you end up doing? Did you find a local shop? I've met with a couple shops in Southern WI and haven't had the best feelings about them.Thx. And I agree, though id need some help to make sure i order it correctly. But i also need the front end regeared and no way can i take that on.
