I have a 32" tire on my stock carrier, so I would say a 31" would not be an issue.Will the stock carrier support a 31x10.5?
Is the Exogate the original heavy duty spare carrier? I also noticed Tactik and Teraflex make one. I want to buy from the original developer.
The original developer was Morryde. Morryde can be directly purchased through Extreme Terrain and a couple other vendors. Gr8tops partnered with them to develop the product, so its not a rip off.Will the stock carrier support a 31x10.5?
Thank you. All the info I was looking for!The original developer was Morryde. Morryde can be directly purchased through Extreme Terrain and a couple other vendors. Gr8tops partnered with them to develop the product, so its not a rip off.
To answer your question will a stock carrier support a 31x10.5 tire? Yes easily. You just need to ensure the snubbers are extended and properly hugging the tire. I have a 33x10.5x15 tire on my TJ with the snubbers extended and it holds up great. The mark for moving away from the stock carrier is usually at 35".
I anticipate getting this product right before I move up a tire size, if that ever happens .
