1. Want to have your TJ featured as the December 2017 "Ride of the Month"? Click here to submit a photo of your TJ. Submissions are accepted until November 20th!
    Dismiss Notice
Speedo Gear Change
Discussion in 'TJ How-to Guides' started by Chris, Oct 31, 2015.
  1. DN EG 3
    DN EG 3 New Member
    Aug 3, 2016
    16
    19
    Central Illinois
    It's a 97 Sahara with an automatic transmission. I'm the third owner, according to the guy I bought it from. I believe it's been modified due to not getting the correct parts, to replace my rear drive shaft u-joints, when I told the parts guy that it is a 1997 Jeep Wrangler Sahara 6 cylinder.
  2. PStov98TJ
    PStov98TJ TJ Enthusiast
    Nov 9, 2015
    548
    353
    Mississippi
    It's normal for it to be off by a greater amount at higher speeds, because the gears all work as a ratio, which means after gear change and/or tire change, our speedometers are "off" by a percentage. Thus, it's off by 10% due to a change in gears or tires by 10%, you'd be 1mph high/low at 10mph, but 7mph high/low at 70mph.
    UpperMI likes this.
  3. Chris
    Chris Administrator
    Staff Member
    Thread Starter
    Sep 28, 2015
    18,231
    9,108
    Salem, Oregon
    Then yes, the 1997 automatic models had an option of 3.55 gears, so you hit the nail on the head.
    DN EG 3 likes this.
  4. DN EG 3
    DN EG 3 New Member
    Aug 3, 2016
    16
    19
    Central Illinois
    HOLY SPEEDOMETER GEAR!!!
    The local dealer said the part is no longer available, but it would have cost me $142 if they had it.
    I don't need to know how fast I'm going that badly!
  5. Chris
    Chris Administrator
    Staff Member
    Thread Starter
    Sep 28, 2015
    18,231
    9,108
    Salem, Oregon
    Amazon has the one you need for $32 plus free shipping:
    https://www.amazon.com/dp/B00EDWL6AY/?tag=wranglerorg-20
  6. DN EG 3
    DN EG 3 New Member
    Aug 3, 2016
    16
    19
    Central Illinois
    $34 at Morris 4x4. That's not too bad
    Chris likes this.
  7. Kyle_W
    Kyle_W Artist formerly known as "Nashorn101".
    Nov 16, 2016
    1,266
    782
    Fulshear, Texas, United States
    I've been curious about this as well - since tires aren't manufactured to PERFECT specs (33" tires being more like 32" tires, etc.) - how can you really know what size your tires are?
  8. Chris
    Chris Administrator
    Staff Member
    Thread Starter
    Sep 28, 2015
    18,231
    9,108
    Salem, Oregon
    It should tell you exactly how big they are on the manufacturer website.
    StG58 and Kyle_W like this.
  9. eddiefast
    eddiefast New Member
    Aug 8, 2017
    8
    4
    San Diego, CA, United States
    great info and shared expertise. But a question: My build sheet for 98 TJ SE says 4.11 gear ratio. I always see 4.10. Why? In any event I assume I just go with the 4.10 for this but still wonder about the ratio delta
  10. Chris
    Chris Administrator
    Staff Member
    Thread Starter
    Sep 28, 2015
    18,231
    9,108
    Salem, Oregon
    It's the same. Some of us just call it 4.10 while others call it 4.11, but they are identical. Not sure why people started calling them by one name or another.
    eddiefast likes this.
  11. IamBR549
    IamBR549 TJ Enthusiast
    Jun 5, 2017
    112
    111
    Ormond Beach, FL, United States
    Next project on list!
    Chris likes this.
  12. JamesAndTheSahara
    JamesAndTheSahara TJ Enthusiast
    May 22, 2017
    926
    713
    Auburn, AL, United States
    I just did mine! Beware, that stupid o ring from the dealer is $10 ea and is backordered currently in the SE. When I removed mine and my peers, both of our orings were in fantastic shape. Make sure whether you reuse or install a new oring that you apply a little bit of ATF+4 around it so it does not tear going in. In the event you go the Stu Olsen route and go to a hardware store to source an oring, you must use a hydraulic oring.
    Goodluck!!
    StG58, Chris and IamBR549 like this.
  13. BumbleJeep
    BumbleJeep New Member
    Jan 5, 2017
    13
    17
    Seattle, WA, United States
    OK... I'm really confused :) My speedo was reading high, so I bought a new speedo gear - my gear ratio is 3.07, I'm running on General Grabber AT2's in LT30x9.5, so I bought and put in a 28 tooth gear. Now my speedo is high by even more! I'm reading 8mph over actual mph...
    very confused...
  14. Chris
    Chris Administrator
    Staff Member
    Thread Starter
    Sep 28, 2015
    18,231
    9,108
    Salem, Oregon
    You sure you have 3.07 gears?
  15. BumbleJeep
    Jan 5, 2017
    13
    17
    yeah, 3.07 tag, and revs match what a 3.07 would do at speed with tire size. very weird, like someone put a speedo healer in-line instead of a gear change?
  16. Chris
    Chris Administrator
    Staff Member
    Thread Starter
    Sep 28, 2015
    18,231
    9,108
    Salem, Oregon
    Since the speedometer on those things is gear driven, I am fairly certain you couldn't use a speedo healer, since it's electronic.
    However, how much faster is it saying you're going at any given speed (how much is it off by)? What did you use to determine this?
  17. BumbleJeep
    Jan 5, 2017
    13
    17
    Thx Chris! I use a Garmin GPS to determine speed - right now 80 indicated on the speedo is 73mph actual. As you'd expect, in the 20's and 30's it's only a couple/few MPH off. The error grows as you go faster. The only thing I can think of is that someone put an electronic adjuster on it somewhere, I'll look more this weekend.
  18. JamesAndTheSahara
    May 22, 2017
    926
    713
    To clarify, the only way an electronic healer could be used & work is if you have a tone ring. Since you physically installed a speedo gear its time to pull it back out & recount the teeth on it to make sure you are correct on the chart & sold what was advertised as a 30 tooth gear. I wouldn't trust revs or tag on terms of gear ratio unless you are the original owner. I would pull the cover & read the gear indicators to know 100%. Because its mechanically driven its hard to see why it would be 7mph off if the gear is correct for the tire size.
  19. Chris
    Chris Administrator
    Staff Member
    Thread Starter
    Sep 28, 2015
    18,231
    9,108
    Salem, Oregon
    X2 to this. Pull the gear out and count the teeth. Also, there’s a very real possibility you don’t have 3.07 gears. Someone could have re-geared it.
Share This Page
