I think the biggest concern I have with the weld in kits that supplement the factory sport cage is, welding the heavier DOM tubing to the factory thin wall tubes without making the surrounding metal more brittle from the heat (warned of this by certified welder that I was originally going to have weld a kit in for me)... The route I have been thinking about is just to replace the sport cage as a whole with the pre-welded kit Poison Spider makes. Not inexpensive by any means though. In the long run I feel it would be much stronger than the factory bars that are multiple pieces bolted together.
http://shop.poisonspyder.com/TJ-Lazer-Fit-Full-Cage-Welded-p/14-19-010-w.htm
Or if you want to save a few hundred $$ and you're capable of wending it together yourself...
http://shop.poisonspyder.com/LJ-Lazer-Fit-Full-Cage-Kit-p/15-19-010.htm
